Old 05-28-2014, 12:12 PM   #1036
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Gravity Rc has 500k diff oil. Sway bars are always a good tuning option.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-28-2014, 12:59 PM   #1037
snuvet75's Avatar
Trader Rating: 16 (94%+)
Originally Posted by GPXJOE View Post
What does the increase in flex do anyway?I haven't tried adding flex
Here is how I usually think of it. Softer chassis means more grip generally to a certain point. Flex adapts the car to optimally respond when the car turns, breaks, accelerates, and changes directions side to side. But the car will respond slower and can get unpredictable especially when you try to change directions quickly, especially if you put too much flex in higher grip conditions. Though, I find that putting more/less flex doesn't make the car react as much compared with other usual changes like droop, roll center, ride height,etc,. It works well in loose conditions to give the car a bit more room to bend to stick to the track floor before it gets loose. I'm really not sure how things can be different in nitro cars than in electric cars but I believe the same physics can be applied. Correct me if I'm wrong...
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 05-28-2014, 01:33 PM   #1038
Was asking about the optional carbon extensions for the rear shock mount and the rear sway bar mount?
bigtee is offline   Reply With Quote
Old 05-28-2014, 06:27 PM   #1039
The away bar mounts could be handy. I never used the shock extensions.
Old 05-28-2014, 06:50 PM   #1040
Default serpent 747
I know the 748 will be out soon. I just want to say the 747 is awesome. Coming from Velox v10 i wished i would have gotten the 747 sooner i will be getting the 748 as soon as it becomes available.
Old 05-28-2014, 07:02 PM   #1041
TAMAK's Avatar
Trader Rating: 28 (100%+)
cant find any 747 rollers... I ill be waiting for used stuff when the 748 comes out....
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 05-28-2014, 07:06 PM   #1042
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
You won't be disappointed! I'll keep my eyes open.
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 05-28-2014, 07:31 PM   #1043
The 748 will be a sweet car.
Old 05-30-2014, 03:52 AM   #1044
Whats the effect of the upper arm pin in towards the chassis (short) or insert flipped and arm long?
JOE SI is offline   Reply With Quote
Old 05-30-2014, 12:50 PM   #1045
NikoRacing's Avatar
I guess you are talking about the front of the car. Like in the rear, the lenght of the links changes the camber rise. If I'm not wrong, at the front, by using a shorter upper arm you have more camber rise. So you'll gain steering in fast and long corners especially. The opposite if you make the arms longer
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 05-30-2014, 08:09 PM   #1046
Perfect, thanks.
Old 06-12-2014, 05:49 AM   #1047
What brand of oils do most guys use for this car?
Better yet, what brand do you think the default setup has?
My guess would be exceed.
I ask because I had 50k mugen in my diff and wanted to go heavier (80k) but the 80k xray oil feels lighter then 50k mugen.
Old 06-12-2014, 07:25 AM   #1048
dan_vector's Avatar
Trader Rating: 27 (100%+)
I use xceed oils but only because it's easy for me to get hold of. The serpent base setups are using Serpent Oil which is included in the kit.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 06-12-2014, 09:30 AM   #1049
in the front differential oil one million, sixty or eighty thousand for the rear this is the configuration that I use regularly
pennesw is offline   Reply With Quote
Old 06-12-2014, 09:52 AM   #1050
I was using 500k in the front and worked good when the traction was high, but when I ran on a track with low traction during practice the car just wouldn't turn in, so I went to 200k and it was much better. With 60,000 in the rear 95% of the time
Tags
rc-world, serpent, serpent 747, toy fair
