Old 05-21-2012, 04:08 AM   #91
Thanks Aaron.
I'll hit Jay up tomorrow.
Simom
Team_Krusty is offline   Reply With Quote
Old 05-21-2012, 06:55 AM   #92
Aza088's Avatar
I must say the last 2x cars i have built have been the 411TE and the 747.
All i can say is that Serpent have turned around the quality of there kits 100%.
all the things fit together perfect plastics better quality metals lighter and fit perfect.
After building both new cars from serpent all i can say is i know i have one of the number 1 quality kits on the market in both classes.
well done serpent i look forward to breaking this baby in over the next week.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 05-21-2012, 07:10 AM   #93
if some know were i can get the new diff case ---pm me .
part no# : 804258
LORD SHADO is offline   Reply With Quote
Old 05-21-2012, 05:54 PM   #94
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Team_Krusty View Post
If only it were that simple.
I have a 1100mAh battery at 33mm wide and hard up against the tank on one side and rubbing on the belt on the other. Need to have something narrower. Even 30mm will probably rub. I know there are a few that are 27 - 29mm. Just wondering what the team guys are using.
The measurements for the xceed lipo look like they will fit (28mm wide) so I will probably just get a couple of these.
Simon
I always used an Orion 1100 ni-mah pack on the 733 without belt rubbing.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-21-2012, 09:24 PM   #95
Aza088's Avatar
part no# : 804258
If its Serpent parts you require check out the below link they are also in stock.
http://www.walterrchobby.com.au/inde...p-housing.html
www.bluerc.net
www.hootrc.com.au
Old 05-22-2012, 02:58 AM   #96
Pattojnr's Avatar
Trader Rating: 19 (100%+)
hope to have mine tommorow, and then start the build .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-22-2012, 04:50 AM   #97
Aza088's Avatar
U will love it the car just fell together I love it let's see how it goes when my new ko hi voltage servos rock up
www.bluerc.net
www.hootrc.com.au
Old 05-22-2012, 11:15 AM   #98
members helping member this what LORD SHADO like!
Old 05-22-2012, 01:44 PM   #99
Cheapest spot online to order 747 kit in USA? Might have to ride the Serpent train.
Tigerbalm is offline   Reply With Quote
Old 05-24-2012, 01:55 AM   #100
im in the u.s.a. need somthin closer!
Old 05-24-2012, 02:48 AM   #101
Aza088's Avatar
Can't help you in USA although i hear a lot about serpent america
Dosen't look like they have stock although.
i know Walter Rc here is Australia has them.
Happy Shopping.
www.bluerc.net
www.hootrc.com.au
Old 05-24-2012, 04:47 AM   #102
lil-bump's Avatar
Trader Rating: 83 (100%+)
Here you go
http://kamikazetoysandhobbies.com/pr...prod=SER804005
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 05-27-2012, 10:52 PM   #103
Default diff problem
747 Diffential tech-tip; prevent leaking diffs
When assembling the differential of the 747, it may occur, when you fill up the diff with oil, some oil enters the holes for the screws that hold the differential together. As a consequence you may have a problem, because you cannot tighten the screws enough due to “hydraulic lock” and the diff will leak oil.
We recommend to drill the 4 holes with a 2.0mm drill all the way through according to the pictures, so the oil can escape from the holes if needed. ( make sure to work safely and wear protection as needed ).
In general make sure not to overfill the diff. When there is too much oil in the diff, the chances that it starts leaking are big, as you cannot tighten the screws as far as needed, or even bend the diff-case.
Old 05-31-2012, 02:28 PM   #104
GMartinez's Avatar
Trader Rating: 85 (100%+)
http://www.superiorhobbies.com/istar...=SER804005!SER
1 left
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-01-2012, 03:03 PM   #105
does anyone know what size collet to use? i have the 18tz motor. the book say use what comes with motor?
Tags
rc-world, serpent, serpent 747, toy fair
