Old 05-21-2014, 06:26 AM   #1021
Stock setup is really good. The only changes I made so far,
500k in front diff, 60k rear, 2.0 rear anti roll bar and blue springs up front.
I also tried the rear shock extensions and liked it enough to leave them. The tracks I run on have real high traction by mid day and the car works good. I still have alot of testing to do, but I found a real good starting point
JOE SI is offline   Reply With Quote
Old 05-21-2014, 06:38 AM   #1022
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by bigtee View Post
Ok thats just diff setup i am talking overall setup
A loaded question. I would start with the default setup and tweak it to your satisfaction. There is no "best setup". the best well rounded setup is a more valid question. And for this; I would use the default setup.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 05-22-2014, 12:35 PM   #1023
What's the reason for cutting the part that holds the front diff in? For flex without using the flex system? Maybe weight?
I noticed he did this on the 747 when redrc showed pictures of his car one other time
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-image.jpg
Old 05-22-2014, 01:13 PM   #1024
gearhead_22's Avatar
Send a message via AIM to gearhead_22
That's the 748 in that pic. Joe
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 05-22-2014, 02:15 PM   #1025
The center body post? That's for more downforce in the front
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 05-22-2014, 02:18 PM   #1026
lil-bump's Avatar
On Mark Green's 747 the graphite top deck was cut. The upper diff bracket was stock. And yes it adds more flex to the front.
Elliott Hart
Serpent America
Desoto Racing Team
Old 05-23-2014, 12:20 AM   #1027
Yes it is the 748.
Just using it as an example. There was another time they spotlighted grenier's car on redrc and he did the same thing
Old 05-23-2014, 12:26 AM   #1028
I saw that too, the 2 front screw holes were cut off.
IMHO, cutting the diff bracket would have more influence on front flex.
Old 05-23-2014, 03:31 AM   #1029
Julius's Avatar
Actually it does not. The diff bracket attaches to the front shock tower which will still prevent flex (unless i pivots on the mounting screws in which case you'd end up with tweak).
The reason for the cut is that it frees up the front bearings a little. You can use a sanding drum on the underside of the nylon diff bracket where the plastic bearing retainer sits. Remove a little material so the bearing retainer can slide left right a little easier. Makes the front a lot more free!
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 05-23-2014, 04:08 AM   #1030
Right, forgot the shock tower.
Old 05-23-2014, 10:47 AM   #1031
What does the increase in flex do anyway?I haven't tried adding flex
Old 05-23-2014, 11:51 AM   #1032
dan_vector's Avatar
Trader Rating: 27 (100%+)
Mainly keeps the front of the body from deflecting at high speed. Keeps the body off the front tyres. Plus it adds strength when you are lifting up the car by the body when refuelling in the pits.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 05-23-2014, 03:05 PM   #1033
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Best place for the center body post is right from the servo saver. It usually lines up at the bottom of the windshield where most times is where the body flexes downward as the car is in motion.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-28-2014, 12:03 PM   #1034
Default carbon shock extensions and anti roll bar
Opinions on these is it really need or it just added bling ?
bigtee is offline   Reply With Quote
Old 05-28-2014, 12:05 PM   #1035
Default diff fluid
Who has 500k diff fluid?
Tags
rc-world, serpent, serpent 747, toy fair
