Old 02-21-2014, 07:52 AM   #886
lil-bump's Avatar
Trader Rating: 83 (100%+)
Stay tuned
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is online now   Reply With Quote
Old 02-21-2014, 04:07 PM   #887
snuvet75's Avatar
Trader Rating: 16 (94%+)
Originally Posted by GPXJOE View Post
Thanks lil bump! Interested to hear your comments on the performance.but in the first place, I don't have any issues with the current clutch in the first place. I mhave issues with the flyweights. The break all the time!
My car is fairly new still but I noticed that the holes in flyweights have been enlarged. Why does this happen anyway guys?
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 02-22-2014, 11:51 AM   #888
It's either the material is not dense enough or the flyweights are too long that the other causes a bind in the other when there is sudden throttle or sudden break. Just my theory. Either way I hope they make a more durable and correct length one if its too long
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 02-22-2014, 11:56 AM   #889
There was once one of them had a hole too small that I had to reamer it a bit squeak it in the flywheel for a while until it loosened. Best practice for now is to always check as much as u can and replace especially if it cracks near the hole where it clings to the flywheel.until they make a better one, thats the protocol.but to be fair to them,a brand new one will not crack until after a one hour final that's for sure
In my last 4 races, I never used one set of flyweights for 2 consecutive races with 80minutes total per race which included practice runs.
Fyi I'm the type of racer who likes to have flawless parts before a main final.but that's me
Old 02-24-2014, 09:42 AM   #890
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Quick Q--- What's the diff gear revision set? part#804259. I'm ordering spares and I noticed this. thanks!
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 02-24-2014, 10:28 AM   #891
lil-bump's Avatar
I been looking at the Dynamis clutch and I wanted to list some of the biggest differences in this clutch and the stock Serpent clutch.
1. All of the clutch pieces are CNC machined "none of the pieces in this clutch seem to be mass produced"
2. I was also told that even the clutch shoes and clutch weights are produced in house.(no outside vendor????)
3. Another big difference is the design of the spring cup and pressure plate.
The spring cup has a machined step in it that will rest into place on the pressure plate when the clutch is assembled. What this does; is that all of the force that is applied to the spring when you tighten it is transferred directly to the pressure plate (not the clutch shoe). The whole idea behind this design is not to distort the clutch shoe when you tighten the spring. Is this a better design??? Only time will tell.
4 The only stock parts that I have found so far; that will NOT fit the Dynamis Evo clutch is the clutch shoe, pressure plate and the spring cup.
5 The spring supplied with the Dynamis clutch is (EXTREMELY) stiff.
I will try to take some pics later this evening.
I'm not here to argue the point of which clutch is better. I'm just stating the differences between the two . I hope this clutch is 10x better than the stock clutch because I spent my hard earned money.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-24-2014, 10:45 AM   #892
lil-bump's Avatar
The 747 diff gears have a smoother action and I believe are smaller than the gears that where offered with the 733. Also the 733 diff gears will not fit the 747 diff housing.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-25-2014, 07:27 AM   #893
Is there a new 747 coming this season?
I was told mid season there will be a new car.
Really hope not, since I made my decision to run this car.
JOE SI is offline   Reply With Quote
Old 02-25-2014, 08:50 PM   #894
Does any body have a set up for the airtronics race in la
Serpent ken is offline   Reply With Quote
Old 02-27-2014, 05:27 AM   #895
dan_vector's Avatar
Trader Rating: 27 (100%+)
Thumbs up
I've heard similar and I guess as it's a WC year something new will be released just in time for the WC. My guess is it'll be an upgrade to the 747 not a completely new car... Either way it probably won't matter as the 747 will continue to be competitive and you'll be able to see the season out with it id have thought!
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 02-27-2014, 05:29 AM   #896
dan_vector's Avatar
Not that I have a setup for that particular track of course! But I usually look at the last few posted team driver setups and make a best guess to use as a starting point for somewhere new to me. It usually is a good all round setup that I don't really need to change much in the end... HTH?
Old 02-27-2014, 05:33 AM   #897
dan_vector's Avatar
Dynamis clutch aside for now.....
What setup are you guys currently running in the stock clutch with regard to measurements, flyweights, clutch spring, shoe, end bell etc?? I'm particularly interested in high bite track setups to see if I'm very far from the current trend!!
Old 02-27-2014, 10:04 AM   #898
Thank you sir, and you answered my next question as well.
That was, will there be an upgrade kit or totally new platform
Old 02-27-2014, 11:12 AM   #899
dan_vector's Avatar
HA! Don't quote me whatever you do the above was just my idea of the situation - I'd prefer an upgrade to a whole new car as I'm used to the 747 and so would like to go to the WC with a familiar platform rather than to learn a new car in short order...
Old 02-27-2014, 12:20 PM   #900
lil-bump's Avatar
I prefer the yellow shoe and steel bell for all conditions. I normally use a clutch gap of .6-.7mm. I use .7 mm if traction is high bite. I use the stock weights and the Serpent 1.8 spring. As for spring tension I always start with the spring fully compressed and then turn it 1 full turn CCW. This is my initial setting and then I tune from this point. Tuning your clutch is all about feel. Setting the spring to a fix number is never the best practice. You should always adjust it on what the track has to offer in terms of grip that day.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Tags
rc-world, serpent, serpent 747, toy fair
