Old 02-06-2014, 04:31 PM   #841
lil-bump's Avatar
Trader Rating: 83 (100%+)
I prefer the hard plactics also. My car feels a little more crisp with the hard plastics. I also get a better fitment with the hard plastics when compared to the medium plastics. This was the case early on; but lately both plastics fit the the same now.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-07-2014, 02:32 PM   #842
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Pass you soon...
Thanks for all the input. I'll build it as it comes and swap out or/and add when I get a feel for the car. Probably add the weights and go from there. The next order would be harder plastics and then the towers and shocks. Seem like a reasonable plan? Which or whose setup sheet seems to be the most dialed?
Thanks again for the help. Just waiting on UPS..
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 02-07-2014, 10:13 PM   #843
dan_vector's Avatar
Trader Rating: 27 (100%+)
Sounds like a decent plan to me. I found the 747 goes pretty well out of the box. I'd put the stock setup on it first, try it and then tune from there. You'll find the updates will change the way the car feels and so you may want to put them on before investing significant time on setup!
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 02-09-2014, 09:49 AM   #844
lil-bump's Avatar
I started with the stock setup but the stock setup has too much on power steering for my liking. I would use Dominic Greiner 2013 ENS or Nacho Lopez Christmas race setup.. These two are the closest to my driving styles.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-11-2014, 04:25 AM   #845
Guys, plastic or aluminum pulleys? Why?
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 02-11-2014, 10:51 AM   #846
dan_vector's Avatar
I use Alu pulleys with low friction belts. The Alu pulleys seem to be more resilient to damage and stripping belts than the plastic pulleys. The Alu pulleys also have dirt clearance holes in the side of them. This prevents the build up of crud in the teeth and the subsequent skipping of the belt. They are also lighter than the plastic pulleys and carriers. So less rotating mass.
Old 02-12-2014, 05:23 AM   #847
Aza088's Avatar
What Alloy Pulleys are you using that are lighter than the plastic?
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 02-12-2014, 05:27 AM   #848
Aza088's Avatar
I use Alloy on the front diff because once you try and tighten the pulley to the diff 2nd or 3rd time the screws tend to warp/egg the pulley and you will notice you front belt go tight then loose while turning the wheels. Some times i will use the rear Alloy diff pulley so i can tighten the diff really tight. Same as front tighten too much the screws start to pop through the plastic pulley. With the alloy one you can tighten until the thread strips and you will still have a straight pulley. All the rest are plastic on my car. But each to there own.
www.bluerc.net
www.hootrc.com.au
Old 02-12-2014, 07:49 AM   #849
That happened to my plastic pulleys.they became misaligned. I got a new plastic pulley then when I screwed it in, I just tightened it to a point that the screw head is just below and tight enough. No leaks. But it was tough,had to reamer the holes of the pulley a little bit.
Someone told me before that alluminum pulleys wear out the belts faster. U guys agree?
Old 02-12-2014, 08:49 AM   #850
After a while, my other car started eating belts at an alarming rate. This was after Hours of run time though. The pulleys(AL.) didn't look that bad either. I'll post up a closeup pic when I get back from the Auto Show...Put new plastics on and ran new belts for the last 3rd of our season. Another 4-5 hrs. of running. All this on a clean, treated track with only a few bumps here and there. I did have some extra time at a big race and drilled "weep" holes in my plastic pulleys for any dirt,foam, etc to get out. Can't just sit there!!
Nick Altieri
Old 02-12-2014, 01:26 PM   #851
WestCoastD's Avatar
Serpent 747 kit - 4wd 200mm, seems to be out-of-stock? Who has stock these days?
WestCoastD is offline   Reply With Quote
Old 02-12-2014, 03:26 PM   #852
http://www.amainhobbies.com/product_...ouring-Car-Kit
Nick Altieri
Old 02-12-2014, 03:33 PM   #853
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Have you checked desoto racing? EDIT...just looked out of stock.
Guys the aluminum pulleys are the way to go...Last longer, doesn't damaged belts, lighter, cleaner. Worth every penny!
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 02-12-2014, 03:47 PM   #854
I know they were worth the $40X5 for my nt1. For $10 each they are well worth it.
I will be drinking a 747 come april. Just can't afford to buy a new nt1 every season lol.
In kissimmee this past December there were nothing but good things said about it, and from guys that were running it for the first time. Nothing steered like my RRR and I hear this is close and even better.
JOE SI is offline   Reply With Quote
Old 02-12-2014, 11:24 PM   #855
WestCoastD's Avatar
A-Main Hobbies
thanks. So, what displacement are folks running in the 200mm class? .12's? or .15's?
Tags
rc-world, serpent, serpent 747, toy fair
