Old 02-01-2014, 02:41 AM   #811
I forgot, I have another problem,after I put the super short front shocks with the lower front shock tower, the spring cup at the bottom of the shocks rubs on the front lower arms.especially if I use the holes furthest apart in the shocktower. Should I shave off the lower arms?I think I have to or else there will be too much weight on the shock axls,it might bend?
Agree?
If I shave, then the arms might lose its strength.
Any suggestions?
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 02-01-2014, 04:46 AM   #812
dan_vector's Avatar
Trader Rating: 27 (100%+)
Originally Posted by GPXJOE View Post
Not in my end,they would have showed it in Nuremberg if there was. How do I.attach the center front body post?
They don't always show it, especially if there is sometime to go until the worlds to prevent copying I guess Anyway rumours usually start around now if a later release is planned. All is quiet for now so lets wait and see - I'm sure there will be WC specific upgrades released at the event. I'm just wandering what they are likely to be as the car is so good right now.
I attach the centre body post to the front shock tower. I use a standard plastic rear body mount from the 747 or 411. Fits perfectly!
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 02-01-2014, 04:47 AM   #813
dan_vector's Avatar
Agree?
Any suggestions?
Photo? I don't have that problem on my car with the SS shocks and low tower?
Old 02-01-2014, 06:47 AM   #814
I used rather the lowest holes nearest the center of the front shock tower.try it, the spring cups touch the front lower arms. When I say spring cups, its the thing that touches the spring at the low side
Old 02-01-2014, 07:43 PM   #815
dan_vector's Avatar
Hmmm. I don't have that issue. Anyone else?
Old 02-01-2014, 08:30 PM   #816
Put it this way,when u screw in the bottom part of the supershort shocks in Front,its like u have to force in the shocks to reach the screw of the lower arm because of the the spring cup rubs on the lower front arm.I use the lowest holes of the lowered shock tower.try doing it,it will rub and screw in the top screw first,ul have a hard time screwing in the bottom
Old 02-01-2014, 09:40 PM   #817
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
A pic would def help, but it sounds like u need to use a 2 or 3mm spacer at the shock mount position on the arm to move the spring retainer out a little bit........
or maybe you might need one where the shock mounts to the tower!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 02-01-2014, 11:22 PM   #818
Aza088's Avatar
Yes the short shocks bind on the front lower suspension arm. We just dremel a little of the suspension arm off to create a grove. No broken arms or weakened arms. don't go too crazy just take enough to clear the spring and spring retainer. Also in the rear if you use the shock extensions we use the standard shock retainer and standard ball cup. Hope this helps.
If you haven't tried the Shock extensions or hand no luck there is a setup on the Serpent website using these extensions.
Enjoy.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 02-03-2014, 06:52 AM   #819
I think il shave off the arm instead of adding shims because I need a lot of shims to have a good gap
Old 02-03-2014, 12:12 PM   #820
dan_vector's Avatar
I'm still interested in before and after shots of the binding/shaved arms. I don't have the problem and would be interested to see what I'm doing different!
Old 02-04-2014, 08:28 AM   #821
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
I ordered my new kit. Besides drilling the diffs to avoid hydrolock, and anything else to look out for? Not a ton of info on SAs website. Any hop-ups you guys feel are needed from the get-go? Thanks.
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 02-04-2014, 08:43 AM   #822
dan_vector's Avatar
Welcome! You'll love the car!
I'd get the new low shock towers and super short shocks as a starter for ten. I also like the hard plastics on the lower wishbones and hub carriers as to me it just seems to sharpen the car up. A nice to have is the alloy radio tray rear mount.
Old 02-04-2014, 08:49 AM   #823
Drill and shave the chassis where it touches the front and rear belts, and the clutchbell
Old 02-04-2014, 08:53 AM   #824
Spray the bearings and put little ball diff grease.this will free up the drive train.and get the sliding weights 2pieces.best option part I got!
Old 02-04-2014, 10:25 AM   #825
I bought Serpent Dans car a while back. I see what you mean about the tolerance between the chassis and belts. Although their is no fraying or other wear marks on the existing belts.
Is the new, lowered shock tower stronger than the version 1? My tower is cracked and seems rather suspect in the durability department. I remember a local guy had his rr. tower reinforced. I forget the material he used. Ran it all summer like that.
Can't wait to start a new build!
Nick Altieri
Tags
rc-world, serpent, serpent 747, toy fair
