Old 01-17-2014, 08:23 PM   #796
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Definitely use the set screws. It will not work properly without them.
Inf1nity CM Beat1 Racing
Serpent-Dan is online now   Reply With Quote
Old 01-17-2014, 09:27 PM   #797
snuvet75's Avatar
Trader Rating: 16 (94%+)
+1
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 01-22-2014, 12:12 AM   #798
snuvet75's Avatar
So I fixed the problem although I blew my throttle servo in the first qualifier in club racing after all that..
It was the 2 speed shoe but I'm not sure what was exactly wrong... funny... I actually widened the gap between the drum and the shoe and problem was gone. Previously I set it in a way that the gap between drum and shoe was minimal. But I also tried to set it wider, too. So I don't know what fixed it hahaha;;;; Well I'm glad it's gone anyway..
Old 01-22-2014, 08:37 AM   #799
Hi can a good soul help?I noticed that my Chevy cruize body is a little too thin that it clips the rear tires. I know I should cut the fender away from the tires but I'm afraid that the tire clips it because the body might be too thin. Is it allowed to put stiffeners on the sedan body?how do u put it?are the stiffeners for 8th scale only or for sedan too?I couldn't find a ruling in the 200mm ifmar rulebook .post pictures please if u have of the stiffeners pretty please?
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 01-24-2014, 03:35 AM   #800
dan_vector's Avatar
Trader Rating: 27 (100%+)
Yes you can put stiffeners around the inside of the body so long as they are not made of metal of carbon fibre! I use offcuts of lexan from the sides and rear of the body that is removed when you originally cut the body out. Bend and form them for the sides and then you can either use double sided tape or small diameter screws and nuts to hold them on. Personally I prefer the tape method. To be honest I mostly do this on 1/8th bodies as I've found my 1/10th bodies don't need it. Just cut the arches so that they clear the tyres when deflected inwards.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-26-2014, 09:05 AM   #801
Guys false alarm. I bumped my rear shocktower. It bent pretty bad forward which caused the posts to move forward.
This will be the 5th time since December 2013 I will buy this rear shocktower. It's flimsy...I hope serpent can make a thicker one,as thick as the rear upper arm holders
Old 01-26-2014, 09:50 AM   #802
lil-bump's Avatar
Trader Rating: 83 (100%+)
If you run the optional body supports on the rear shock tower this breaks the shock tower if you roll the car. Try running the support brackets with no extentions or removing them all together.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-27-2014, 07:35 AM   #803
Pass you soon...
Ya I was just thinking that. I will try first with less extensions to make it shorter and more tucked inside the car.if it still breaks,will remove it altogether. I should have more steering without rear extensions?
Old 01-27-2014, 03:21 PM   #804
snuvet75's Avatar
Pass you soon...
That's a bad news cuz I just ordered 2, one for 747, one for S411
Old 01-31-2014, 11:28 PM   #805
Try it anyway bro. It's worth testing with and without it. Either way, its a hazard only if u get clipped real good from behind, that's the only drawback I see. But the thing is if its not there, where else will we position it? No where else.
What I did was I drilled the holes of the extensions thru and thru tjen I put a long screw which protrudes through.this way the extensions won't come off for sure if I'm bumped from behind but that still will not stop the shock tower from bending. I also got the lower shock tower which happens to be thicker! I also put the super short shocks that are the only ones that go with the lower shock tower.will post pics
Old 01-31-2014, 11:37 PM   #806
Default pix of thicker lower shock tower
Pix of thicker and lower shock tower
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-imag0649.jpg
Old 01-31-2014, 11:43 PM   #807
I thought I saw Paolo morgantis car had a body post right at the servo saver.how did he do that?a super long screw from under the chassis?why there? Harder hood?
Old 02-01-2014, 01:09 AM   #808
dan_vector's Avatar
The third front body post as I refer to it stops the front deforming at high speed so that high speed downforce is maintained and is useful at tracks with fast corners. I have always used the 'third body post' on all my 200mm cars. I don't bother with it on 190mm electric TC's.
Old 02-01-2014, 01:26 AM   #809
dan_vector's Avatar
Any rumours of a new car from Serpent for the WC?
Old 02-01-2014, 02:34 AM   #810
Not in my end,they would have showed it in Nuremberg if there was. How do I.attach the center front body post?
Tags
rc-world, serpent, serpent 747, toy fair
