Old 10-29-2013, 10:16 AM   #706
Hey guys just to share some news, serpent takes top 3 spots in 8th and 10th scale in manila!all xceed tires too
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 11-02-2013, 08:01 PM   #707
Evo 13's Avatar
Hey Serpent Dan, and everyone else with a 747.
I'm ready to get the 747 but wanted to know what is a good fitting
Life battery preferably Protek for the car? Same Question for those with the 977 viper?
Thanks in advance!
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 11-03-2013, 08:15 AM   #708
snuvet75's Avatar
Trader Rating: 16 (94%+)
Thanks in advance!
I'm new to 747 too. At least I know Reedy pack fits perferct.
I didn't know I was supposed to use LiFe when I bought this car. Later my friend told me I need to because NiMh would not fit. But I made it work NiMh is a bit wider than LiFe but you tape it as to the middle as possible on the battery holder and you will have 3mm clearance from the side belt. LOL
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 11-03-2013, 08:16 AM   #709
snuvet75's Avatar
Side belt seems to rub against manifold? I has already worn down the words on the belt but belt itself seems fine. How do I avoid this friction?
Old 11-03-2013, 09:32 AM   #710
dan_vector's Avatar
Trader Rating: 27 (100%+)
I guess you've already tried to tighten the belt tensioner slightly? What engine/manifold combo are you using? I have run Picco, Xceed and Novarossi engines in my 747 an never had an issue with the belt rubbing on the manifold unless the tensioner was fully up. HTH.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 11-03-2013, 12:20 PM   #711
Evo 13's Avatar
Thanks, how do you like the 747 overall. Is it really fast out the box or do you have to invest considerable set up time to make it go?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 11-03-2013, 07:15 PM   #712
Mount the side belt tensioner beneath the radio tray. This will alllow more adjustment to push the side belt downwards and away from the manifold.
peppernick is offline   Reply With Quote
Old 11-04-2013, 10:23 AM   #713
Evo 13's Avatar
Was there ever an update to the 747 kit, such as the low cg shock towers and the shocks from the electric car, or is the car unchanged from its original release in 2012 and these parts represent optional hop ups?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 11-05-2013, 02:07 AM   #714
Julius's Avatar
At present the short shocks and towers are optionals.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 11-05-2013, 09:29 PM   #715
Evo 13's Avatar
Thanks, just ordered my 747
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 11-06-2013, 07:45 PM   #716
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Thanks in advance!
Not sure on the Life packs. I'm using an Xceed li-po pack at the moment. Very light weight fits great.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 11-06-2013, 08:04 PM   #717
Evo 13's Avatar
Which one? and do you use a regulator with it? Sorry for all the questions, I just want to set the car up nicely.
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 11-12-2013, 07:39 PM   #718
Hi, Do I need to have the carbon bumper plate to be able to use the foam bumper ? or the plastic one that comes with the kit can fit the foam bumper as well?
Thanks.
I like cat.
frozencone is offline   Reply With Quote
Old 11-13-2013, 06:53 PM   #719
lil-bump's Avatar
Trader Rating: 83 (100%+)
[QUOTE=frozencone;12720006]Hi, Do I need to have the carbon bumper plate to be able to use the foam bumper ? or the plastic one that comes with the kit can fit the foam bumper as well?
No, If you want to run a foam bumper I would run the plastic top bumper not the carbon. I would also get the wide front foam bumper rather than the stock. Look at the manual for the 733 it will Illustrate what parts are needed.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-13-2013, 08:13 PM   #720
Evo 13's Avatar
Default Diff Oil
Hey guys,
I'm a little confused, I'm in the process of building my 747. Do I use the 300000 diff oil on the front and rear?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Tags
rc-world, serpent, serpent 747, toy fair
