Old 08-29-2013, 08:40 PM   #646
lil-bump's Avatar
Trader Rating: 83 (100%+)
Actually we are both right. It all depends if you reference the clutch weight at the 12:00 position or at the 6:00 position. At the 6:00 position you would use the left hole and at the 12:00 position you would use the right hole.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-29-2013, 09:36 PM   #647
Jazza's Avatar
Trader Rating: 16 (100%+)
Pass you soon...
Very true & best way to describe it lil-bump
Capricorn Lab Co3....Black Edition Co2
Kickass Racing OS Racing Engines RB TXR Engines
Capricorn Racing Tyres....Highest Servo's....VP Racing Fuels
Supporter of Capricorn Australia....Walters Hobbies....JPM Racing
Jazza is offline   Reply With Quote
Old 08-30-2013, 12:58 PM   #648
djiewie's Avatar
we are all right , it all depends how / what you mean
.--------- the pin is leading looking at the front of the flywheel front upper pin but the weight is trailing (agressive)
----------. the pin is trailing looking at the front upper pin but the weight is leading (soft setting)
if you say the weight is leading than M7H is right , and that is what he said. But the answer was yes.
i know pictures are better , but i am plain lazy
now correct me if i am wrong, trailing weights will give more force on the shoe, leading weights will give less force.
@M7H See you on sunday, i am assisting the referee.
djiewie is offline   Reply With Quote
Old 08-30-2013, 01:37 PM   #649
lil-bump's Avatar
Here you go:
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-weight.jpg
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-30-2013, 02:38 PM   #650
Julius's Avatar
Here you go:
And those are leading weights. In the rotation direction, the shoe leads the pin...
Leading weights are considered to give a more agressive clutch. This is because as the engine revs up the inertia of the shoe helps the shoe outward.
The difference is not very big in my opinion. There is more difference when you put small setscrews in the open hole of the shoe.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 08-31-2013, 12:59 AM   #651
djiewie's Avatar
now looking at it ,it seams to me there is no differance other than that the weights won`t rip at the hole on the pin when mounted leading because the pin is pushing the weight. When pulling the weight there is much less material where the pulling force is applied and thats why the weights get distorted and break at the hole wich i have had because i use the trailing way of mounting. But some weights have only one hole so you mount them so it fits and that was trailing.
going to try leading weights.
Old 08-31-2013, 09:44 AM   #652
A portion of mine tore off near the hole when I did Michael salvens way. So I just replaced it. I feel uneasy experimenting with this going the other way.
Serpent 748/Nova Virtus/Sanwa M12/Maxima/Savox Brushless/Xceed
GPXJOE is offline   Reply With Quote
Old 09-09-2013, 01:09 AM   #653
Geberit's Avatar
Hello,
After three years of electric 1/10TC I decided to start with nitro again. Since I drive the Serpent S411ERYX I will go with the S747. Because I didn't follow the scene too much I have a question regarding option/tuning parts that I have to look after for the car? Any advice would be great.
Thanks, Lojz
Geberit is offline   Reply With Quote
Old 09-09-2013, 05:45 AM   #654
Originally Posted by Geberit View Post
Hello,
Thanks, Lojz
So far I've only used the optional spring set the car has been very solid. Maybe grab the springs and a few spurs then call it good.
TerribleTy is offline   Reply With Quote
Old 09-09-2013, 05:58 AM   #655
Geberit's Avatar
Nice to hear no big upgrades needed, thanks for the input!
Old 09-10-2013, 12:02 AM   #656
Geberit's Avatar
What dimension is the battery? Any suggestions for a LiFe?
Thanks ...
Old 09-10-2013, 01:58 AM   #657
Im using the LRP Life pack, but it is very tight.
Radiopost TS401
SebO is offline   Reply With Quote
Old 09-10-2013, 03:35 AM   #658
Julius's Avatar
Thanks ...
I use the xceed pack.
Dimensions - 80 x 28 x 13mm excluding wires
Especially the width is quite critical. About 30-31mm is max.
This is a pack I'm about to test: http://www.conrad.nl/ce/nl/product/2...systeem-EC3-TP
Old 09-10-2013, 05:15 AM   #659
Geberit's Avatar
So this one should be fine: http://www.reedypower.com/products/details/305/
Old 09-10-2013, 05:27 AM   #660
Jazza's Avatar
Default LiFe Batt
Thanks ...
A very good racer & friend from my track recommended the KM LiFe pack to me.
Fits perfect is 1300mha & you won't have any drama's.
Cheers Daz
Tags
rc-world, serpent, serpent 747, toy fair
