Old 08-14-2013, 11:52 AM   #616
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
A quick cure for too much steering. Put glue on the front tires edges.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 08-14-2013, 04:36 PM   #617
bigbank66's Avatar
Originally Posted by 1evo RRR Driver View Post
Well had my 1st raceday with my 747........qual went ok, i was only a few seconds off the pace over 5mins.....(TQ 21 5:14 ) 20 5:02 20 5:06 20 5:07 20 5:08 ( I had 20 5:09) car was ok, drivable in the morning, as it warmed up n traction went down my car became almost undrivable..... Default setup calls for 1000cst in shocks (i put 600cst) wrong move! Again default for rear diff is 30k (i put a 100k) wrong move! I guess what i was doing was trying to make the car feel like my other cars on the "bench" n it did....but that didn't work on the track......anyway had a horrible main..had the duel rate down to 130 from 150 n still with half input the car wanted to hook, i pulled over for everyone! Even the bump position from the B! Lol impossible to go fast when the confidence isn't there.....So next day went back to the track, with 1000cst which by the way is (80w associated) n 40k in the rear diff.......n car was night n day.......couldn't make it hook to save my life.......so I'm back smiling at the switch!........after that started playing around with the caster clips, n got a real good feel from more spacers in front of arm.....will try more behind arm at next practice day.....also stiffer rear bar.....
Good to hear the car is better...I knew 100k in the rear was too much....
bigbank66 is offline   Reply With Quote
Old 08-14-2013, 06:24 PM   #618
lil-bump's Avatar
Trader Rating: 83 (100%+)
What hole piston are you running with the 1000 cst? With the RCM shocks, I run 600 cst both front and rear with a 1 hole front and 2 hole rear piston.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-14-2013, 11:16 PM   #619
Serpent007's Avatar
Quick question, what r you guys doing for the leaky diffs? I heard serpent had this prob with the 733 my 747 i just got had the same prob with the rear diff....until i changed to a thinner orange o ring.......if u've experienced this, what did u do??
The serpent site tells you to make the holes slightly larger by drilling them and how to perform the mod which is easy, I've only had one leaky one which was the 1st rushed assembly & IMO due to how i assembled it, currently I've got 4 diffs for my 747 ready to go, the two in the car are standard 4 gear and the other 2 are set up with 2 gears, all of them are standard unmodified housings and haven't had so much of a hint of leak/s.. I think a fair bit depends on how it's put together or maybe I'm just lucky, I haven't had to do the tip suggested by serpent "incase" it happens, def dosnt happen to all I know that for sure..
Ive got about 7-8 diffs all up so ill drill a spare out and see what results it gives, or if the assembly is a little less easier on tolerences all round, but so far I've been lucky..
~Serpent 747 -2013 upgrades~ 2013 REDS Racing M3-WCup Team Tuned Engines~
~2013 REDS Hipex Mr Tuned pipe set/s~ Savox~ Spektrum~ Enneti~ SRS-N/P37~
-- BSP "Ben Sterling Products Melb" --
~~~BIG THANKS TO "WALTER HOBBY RC" 4 LOADING ME UP WITH GOODS!~~~
Serpent007 is offline   Reply With Quote
Old 08-14-2013, 11:40 PM   #620
Serpent007's Avatar
Originally Posted by eracer99 View Post
Up until now I used a 5 cell NiMH battery. But this RX battery is just fitting. It is sitting very close to the side belt, the fuel tank,... My side belt even rubbed against it.
So I'm looking for a smaller RX battery, maybe e Life battery.
I borrowed a 1600 mAh Life from a friend to test it. This had a size of 85x30x17mm and i also was very thight and ther is even an extra balancing plug to fit. This life wasn't much smaller than the NiMh.
What battery do you use for a S747?
Was using the same, 5cell NiMH pack but mine was in decent clearence of the side belt/tank, I'm currenty running a LiFe atm, which was almost the same depth/fit, a little more narrower giving even more clearence to the belt etc
This is what I'm running below.. I've also got a exceed lipo but prefer not to use lipos due to volt reg etc..
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-image.jpg
Old 08-14-2013, 11:59 PM   #621
Serpent007's Avatar
Default That was a nice door knock...
Don't you love it when things get dropped off unexpectedly...
3drawer serpent pitbag...
Fits all new packaged parts in the middle drawer
Good and specialised Tools in the top drawer
And the 747 sits snug in the bottom one.... Awesome!!
Old 08-15-2013, 12:01 AM   #622
Serpent007's Avatar
Old 08-15-2013, 07:57 PM   #623
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Yeah I drilled out the holes to the rear diff to use bigger screws, I'm good now! I think the small screws with the Phillips head just didn't get tight enough......(didnt help that I stripped one also). And i also changed the O ring to a orange one I got from my buddy, no leaks ever since......
The front I think the oil is just to thick to leake out! 300k
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 08-16-2013, 10:49 PM   #624
Default 747 options!!
Fellas quick question, Have any of you played around with cutting out the hexagon shapes on the front lower bumper? (I see its done on Dominics 747) Also regarding springs, Can u run short fronts n long rear? Or should you not mix front to back? Do long springs offer a different feel than short? Should I not use short at all?
Old 08-17-2013, 04:39 AM   #625
Serpent007's Avatar
I've cut one of my spare bumpers far hex edges out, haven't tried it yet unfort with rain when ive got abit of time, i will in the next week, it's meant to be a noticeable change,
also the the 25G chassis weight slide makes a HUGE diff if you haven't tried or have it yet, slide it right back and it gives a ton of steering "even tho there is plenty without it" but at expenses of heavier rear tyre wear, slide front gives less steering and more front tyre wear, good to play around and good if your running mixed tyre to find that sweet spot or balance.. It's been interesting to see the diff it makes..
Re the springs, i've got the SS shock set and low towers and standard set, I've never mixed springs though, I've just started running the 2013 super short shock set and low towers with good results..
Old 08-17-2013, 08:58 AM   #626
Serpent 747 2013 Euro Champ!!! Great job 1st and 3rd.
Old 08-17-2013, 10:47 AM   #627
lil-bump's Avatar
I always run my bumper with the outer hexes removed. I feel it gives better initial turn in. I've tried running long springs in the rear. The only problem is you will run out of adjustment on the collar if you run tall tires. The long springs are just a tad too long.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-17-2013, 11:19 AM   #628
Pass you soon...
Thanks, but my car came with long springs! So u prefer short only for that reason? No handling differences?
Old 08-17-2013, 04:01 PM   #629
lil-bump's Avatar
I never tried them because I could not set my ride height. I ran them on my 733 but the 747 has different rear geometry.... Way go team Serpent @ the ENS in Austria. Good job!!!!
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-17-2013, 09:30 PM   #630
Aza088's Avatar
Exclamation
Never had much success with the holes cut in the bumper but is on my list of things to test again.
We run the long springs with the shock extentions and have had great success
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
