Old 06-25-2013, 12:55 AM   #511
Aza088's Avatar
Originally Posted by Michael_T View Post
Aza,
What are the Ulti combo fronts equivalent to? I use Ulti 37F/40R (99% of the time), so did you find 40R to work best with the combo fronts, or did you go to 37R?
Picking up some from Jay today, not sure what rears I should match them with?
Hey mate,
I found them best with 38 rears they wear good together and I have some ZAC project if you would like to try shoot me a pm if u would like some.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 06-25-2013, 03:35 AM   #512
Thank you Julius I will experiment with these setups.
Regards,
Frank.
FrankP is offline   Reply With Quote
Old 06-25-2013, 06:59 AM   #513
Aza088's Avatar
Some setups to try and test.
Enjoy.
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-aaron-lee-747-john-grant-raceway-april-2013.jpg   Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-aaron-lee-747-john-grant-raceway-nov-2012.jpg
www.bluerc.net
www.hootrc.com.au
Old 06-25-2013, 06:14 PM   #514
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally Posted by Aza088 View Post
Hey mate,
Thanks, i picked up some Ulti Combos, will test these first.
Michael_T is offline   Reply With Quote
Old 06-25-2013, 11:18 PM   #515
shiston's Avatar
Hi,
I noticed in the setup sheet that it shows the option of running the diffs with either 2 or 4 of the small gears. What's the difference for example if you have 2 diffs filled with 30,000cst fluid, and one diff has the 4 gears and the other with 2 gears?
Hang around......we'll talk some more
shiston is offline   Reply With Quote
Old 06-26-2013, 03:27 AM   #516
Bundy_Bear's Avatar
Originally Posted by shiston View Post
Hi,
Four gears would give more resistance, so only running two gears would be like running a lighter oil. People did this in the front diff of the HPI R40 back in its day...
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 06-26-2013, 06:30 AM   #517
Michael_T's Avatar
Hi,
I always run 2 diff crowns, diffs feel smoother, never had any strip, and some weight saving benefits.
You need to double the diff oil rating, ie..
30,000cst 4 crown = 60,000cst 2 crown
Old 06-26-2013, 06:49 AM   #518
lil-bump's Avatar
Trader Rating: 83 (100%+)
I like the feel of 4 gears. Also when you're dealing with thicker diff oils your choices of various weights becomes very limited above 100K. It's personal preference thing.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-26-2013, 08:47 AM   #519
JJBinks's Avatar
Pass you soon...
From my experience at our Toledo Track, Most all guys running sedan like the feel of 4 gears over 2, but like you said its all preference.
Jon Strausbaugh
2016 Great Lakes Challenge Race Director
Great Lakes Challenge Coordinator - One Eighth Racers
www.ToledoOneEighthRacers.com
Serpent Natrix 748, Revenge .12, Desoto Racing, Futaba
JJBinks is offline   Reply With Quote
Old 06-26-2013, 05:24 PM   #520
shiston's Avatar
Thanks for the replies regarding the diff gears. Much appreciated
Old 06-27-2013, 04:08 AM   #521
Lessen's Avatar
Send a message via MSN to Lessen
@ JJBinks: What tires are the Serpent guys running over at Toledo? (Brands/most popular compounds) I'm planning to put together a nitro program and this is one area I really don't know much about yet.
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 06-27-2013, 07:35 AM   #522
lil-bump's Avatar
On a normal day I run 38 fronts and 40 rears. When traction gets high I go to 40 fronts and 42 rears. In some cases I've used 38 fronts and 42 rears (tons of steering).
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 06-27-2013, 10:43 AM   #523
JJBinks's Avatar
On a normal day I run 38 fronts and 40 rears. When traction gets high I go to 40 fronts and 42 rears. Im some cases I've used 38 fronts and 42 rears (tons of steering).
Pass you soon...
+1 to that. In some rare cases in the past I have seen some sedans run 35 from 38 or 40 rears. but that is a rarity.
Jon Strausbaugh
Old 06-27-2013, 10:45 AM   #524
JJBinks's Avatar
Besides Compound the tires I see the most run at our track are Enneti and Matrix. I plan to run Enneti for the most part.
Jon Strausbaugh
Old 06-27-2013, 10:50 AM   #525
lil-bump's Avatar
I normally run Enneti fronts. Enneti's fronts are the only tires I've found that can be used with the narrow hex drives up front. All other tires rub on the steering knuckles arms .
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Tags
rc-world, serpent, serpent 747, toy fair
