Old 04-28-2013, 01:28 PM   #436
GREGORY!'s Avatar
Originally Posted by GPXJOE View Post
plus 1 on that question above.
fyi, here is a video of my neon yellow 747. engine was at 102 degrees, a little rich. please finish the video, you will hear the 2speed engage later after the engine heats up.
comments on the set up, driving, and clutch please. i set my clutch a little loose because i dont want too much drastic clutch engaging, its hard to make the car settle at a very tight clutch for my driving style.
tires 37fr 37 rear, exceed, nova flash 102degrees on the m12 tempguage in the end of the run. orange springs front and rear. i moved forward the upper front arms, this change seemed to give me more onpower steering, instead of waiting for the car to turn then add more throttle. i liked it!!
here's the dogfight video
http://www.youtube.com/watch?v=4MvA_...ature=youtu.be
to make us serpent drivers feel better, i smoked the other car in the end hehe
I feel that the second gear has a bit late engagement point.
1/4 unscrew, maybe more.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 04-28-2013, 04:22 PM   #437
Hi Guys
what is the difference between the red clutch shoe and the yellow?
Blown1940 is offline   Reply With Quote
Old 04-28-2013, 07:30 PM   #438
lil-bump's Avatar
Trader Rating: 83 (100%+)
Originally Posted by Blown1940 View Post
Hi Guys
The yellow slips a smidge more than the red. I prefer the yellow with the steel bell. It has the widest sweet spot. The red is a little softer than the yellow.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-28-2013, 07:41 PM   #439
lil-bump's Avatar
Originally Posted by lil-bump View Post
Gentlemen...... My snake is ready; I've got some things to test... But my Snake is ready......... 747!!!!!!!
Pass you soon...
+1
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-30-2013, 08:04 AM   #440
nitrobeast's Avatar
Trader Rating: 41 (100%+)
I've got a question. When dealing with the front and rear wheel base on the 747 setup sheet. If you place the lower castor clips 1 in front and 1 in back of the lower arm is this considered "-1"? and if both clips are in the most forward position this is considered -2? Is so; If both clips are in the rear position this would be 0
Pass you soon...
Yes
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 05-01-2013, 07:54 PM   #441
are the rear diff. of the serpent 747 the same as the rear diff. of serpent impulse?
vintage boy is offline   Reply With Quote
Old 05-01-2013, 11:54 PM   #442
BardSmith's Avatar
Trader Rating: 62 (98%+)
I'm about to head out with my new 747 for a race weekend, which spare parts or option parts should I stock up on? What's breaking out there? Ideas... thoughts...
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 05-02-2013, 12:07 AM   #443
Front end arms, Uppers and lowers. .
I find the 733/747 arms to be the weak link in the front end. Broken a few with some very little taps... Other then that acouple extra spurs.. That's about it.. Solid car otherwise.
Shawn.
Shawn68z is offline   Reply With Quote
Old 05-02-2013, 06:28 AM   #444
nitrobeast's Avatar
Here is what ive replaced the last two weeks.
Lower/upper front arm
Steering rod ball cups
spur gear, my fault motor moved
rear shock tower, traction roll and rear tower will eventually crack.
Rui Goncalves
Old 05-02-2013, 08:56 AM   #445
Julius's Avatar
No, completely different.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 05-10-2013, 09:13 PM   #446
lil-bump's Avatar
I've only went thru rear lower arms. Never hit the boards a$$ first
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 05-12-2013, 12:42 PM   #447
PNT2000's Avatar
+1
very nice.....
PNT2000 is offline   Reply With Quote
Old 05-13-2013, 08:08 PM   #448
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
New 747 options??
Low shocktower to be able to mount the RCM Super-Short shocks # 160124 and this lower center of gravity. Continue to use your current springs, so special short ones needed.
http://www.serpent.com/product/804306
and
http://www.serpent.com/product/804305
Michael_T is offline   Reply With Quote
Old 05-15-2013, 02:28 AM   #449
kickass's Avatar
Originally Posted by Michael_T View Post
New 747 options??
and
I Want
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 05-15-2013, 04:34 AM   #450
Jazza's Avatar
Trader Rating: 16 (100%+)
Originally Posted by kickass View Post
I Want
You are already too FAST
Capricorn Lab Co3....Black Edition Co2
Kickass Racing OS Racing Engines RB TXR Engines
Capricorn Racing Tyres....Highest Servo's....VP Racing Fuels
Supporter of Capricorn Australia....Walters Hobbies....JPM Racing
Jazza is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
