Old 02-01-2013, 10:07 AM   #361
Does anyone know if there will be any update to this car for 2013?
Sti2 is offline   Reply With Quote
Old 02-01-2013, 10:29 AM   #362
Originally Posted by wad View Post
They are filters, the one going to the engine in to get more mileage from one gas tank. The one going from the pipe to the gas tank is to get constant pressure.
They will be needed if there is a bad designed gas tank, the 747 gas tank has no problems with size or pressure, so you will not need them.
I use Keep-on engines with no filters at all. And have good run time (over 5 minutes) and the presure is stable (engine doesn't get lean or rich at all).
Thanks.i saw other use a heat sink in the pressure line for offload buggy like Robert battle. If no one uses it then ok why fix something that ain't broken,thanks walter
GPXJOE is offline   Reply With Quote
Old 02-01-2013, 10:32 AM   #363
Who makes option parts for 747 that are cheaper than the original serpent parts?i saw another brand for the aluminum Pullies that wer cheaper.does anyone know what brand it is?i forgot the brand
Old 02-04-2013, 07:00 AM   #364
Whats a good steering and throttle servo for this car? I need a good balance between right and left side of the car. Im using a 2652 pipe with a life rx battery on the left then a sanwa rx on the right, so the servos are the last thing i need to get. Thank you so much!
jusandsil is offline   Reply With Quote
Old 02-04-2013, 02:13 PM   #365
Send a message via Skype™ to carletto
TE edition ???????
carletto is offline   Reply With Quote
Old 02-04-2013, 03:45 PM   #366
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Maybe CSO or Arrowmax
I run Futaba BLS551s for both steering and throttle. Along with a LiFe battery and light weight body, weight is around 1,660grams. My preference would be to run a stronger/faster standard size steering servo, but with the new weight rule, will leave it low profile to save weight. You can't go wrong with Futaba or Sanwa servos.
Originally Posted by carletto View Post
TE edition ???????
I doubt it anytime soon. One good thing about the car is there are very few option parts available. The car comes with all the fancy aluminum and lightweight stuff already.
Michael_T is offline   Reply With Quote
Old 02-05-2013, 05:40 AM   #367
I was considering the bls551 too, together with the ko rsx one10 servos. Whats the weight of your pipe and life battery combined? What about your rx? I would like to get the best servos so that i can achieve the best left and right balance of the car. Arent lightweight bodies not allowed in ifmar sactioned events? Sorry for all the questions, im new to nitro onroad and theres no one here who i can ask questions regarding the 747. Serpent is banned in the onlt onroad track and people just built a new one where all are allowed but they run GT.
Old 02-05-2013, 06:52 AM   #368
howardns's Avatar
i have used the Airtronics RX461 with savox 1251 low profile digital servos with the 747 for about 7 months now with no problems.
my life pack weighs 73 grams, my lipo weighs 70 and the novarossi 2660 with med header is about 70 grams. with body, enneti carbon rims 59/57 it is under 1670 grams and that is about the min. weight i want to run to not be under weight with really small tires
Serpent Cobra GT
Homestead RC Raceway
howardns is offline   Reply With Quote
Old 02-05-2013, 02:19 PM   #369
lil-bump's Avatar
Trader Rating: 83 (100%+)
I've heard of this before. But why would Serpent cars be banned?
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-05-2013, 09:34 PM   #370
If the life battery and the pipe and manifold weighs around 143grams on the left side, isn't it better to use standard size servos? what would be the best servos to use so that the left and right balance of the car is equal without using counter weights so that I can still achieve a light car.
I don't really know the real reason but its just like that. Good thing that people built a new onroad track but the new problem is they run 1/8GT not 1/10.
Old 02-06-2013, 02:46 AM   #371
Julius's Avatar
Because they were too fast....
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 02-12-2013, 11:47 AM   #372
Hi guys,
Im here in taipei taiwan now on vacation, does anyone know who carries 747 parts here?
My rear lower arms are a little torn but i did a mcgyver fix but if i can find new ones then great! Does anyone know where here in taipei? Thanks!
Old 02-12-2013, 08:11 PM   #373
asc
Has anyone come up with a fix for the side belt hitting the bottom of the exhaust manifold? I cannot change motors at this point in time, and this is really frustrating.
Also, does anyone else find the exhaust hanger/spring too short and difficult to stretch/bend into the right shape? Are there any other options in this area?
asc is offline   Reply With Quote
Old 02-13-2013, 06:23 AM   #374
kickass's Avatar
Grind your manifold and tighten your belt.
Bend another one out of piano wire. the orig one is ok though
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 02-13-2013, 10:15 AM   #375
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
What motor are you using? I have no problem with Novarossi engines.
There is no need to modify the original holder, it brings the pipe as close to the side pulley as possible. Or you can make another one as kickass mentioned.
Walter Diaz
wad is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
