Old 01-25-2013, 12:26 AM   #346
Originally Posted by wad View Post
I normally shave the arms in the rear side for about .4 mm, then use a 1 mm spacer in the front and a 1 mm spacer in the back of the arm.
After that the arms move free.
Hope that helps.
hi my rear arms are fine, the front lower arms are my problem. i think it is because with a 0.6mm play for new arms, it should even loosen more after i run it.
i have 2mm shims in each side, il sand an extra 1mm agree?or sand the arm?
GPXJOE is offline   Reply With Quote
Old 01-25-2013, 11:10 AM   #347
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
I was refering to the front lower arms. I shave them in the rear part to make the car shorter.
I believe the lengh of the arms are 63.4, and they should be 63.0 in order to use 2 of the 1mm clips.
Walter Diaz
wad is offline   Reply With Quote
Old 01-25-2013, 12:29 PM   #348
lil-bump's Avatar
Trader Rating: 83 (100%+)
.6mm is a little much. I would double check your front and rear brackets and see if you can decrease the slop there first. If you can not; Kysho makes a assortment of metal round shims that will fit over the pins KY- 96641
Also Serpent makes the flywheel shims Serp-6599 these shims go behind the cone which will move the clutch assemble out to better match the placement of the spur gears.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-26-2013, 09:26 AM   #349
What a relief! I never thought of metal shims.i believe that's better than sanding the shim.i also ordered the 6599part thanks I really needed that solution.
As always,u guys are truly great thanks.
Old 01-30-2013, 04:14 AM   #350
Default confused.
hi guys, do i have the flyweights the right way around? the instructions show two different things
is my photo correct?
thank you.
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-flywheel.jpg
implusepro is offline   Reply With Quote
Old 01-30-2013, 07:55 AM   #351
lil-bump's Avatar
thank you.
Yes that is correct. The shoes should be leading the pins.
Elliott Hart
Serpent America
Desoto Racing Team
Old 01-30-2013, 11:17 AM   #352
hi guys what is the softest shock springs to the hardest springs? i have the red which came wih the kit. why are also different lengths of springs? do i have the shrt absorbers which came with the kit?
Old 01-30-2013, 04:39 PM   #353
thanks lil-bump. i was running them the wrong way for about 6 races
is there any difference between the two, because the clutch felt ok running them the other way
also, is 0.5mm clutch gap ok
thanks again.
Old 01-30-2013, 05:21 PM   #354
lil-bump's Avatar
thanks again.
Running the weights the other way "trailing" makes the clutch less aggressive. I normally start with a clutch gap of .6mm. If traction is good I've went up to .7. .5 is a little too small for the tracks I run on. If traction is low I would believe .5 would work fine.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 01-30-2013, 05:27 PM   #355
lil-bump's Avatar
The long springs I believe were actually used on the 966. But some of the team drivers posted that the use of long springs on the rear of the 733 gave better performance. So i guess this carried over from the 733 to the 747. If you do a search in the 733 thread the spring rates are listed; if not, I will have to dig them up. The 747 kit came with the same length absorbers front and rear
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 01-31-2013, 05:01 AM   #356
howardns's Avatar
i have a spring chart
send me a pm with your e-mail
Serpent Cobra GT
Homestead RC Raceway
howardns is offline   Reply With Quote
Old 01-31-2013, 08:12 AM   #357
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
thank you.
I thought the bevel on the shoes would face the flywheel for a bigger contact patch..
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 01-31-2013, 08:51 AM   #358
Flywheel is flat...
Wachsmann64 is offline   Reply With Quote
Old 01-31-2013, 11:44 AM   #359
Pass you soon...
found it thanks!
i saw in some pics of other racers, they put something on the pipe hose( pressure line) and somthing else in the fuel line, are they both fiilters? or heat sinks? what type and brand are best for flash .12 nova?and how long should the fuel line and pressure line be?
Old 01-31-2013, 11:57 AM   #360
wad
wad's Avatar
found it thanks!
They are filters, the one going to the engine in to get more mileage from one gas tank. The one going from the pipe to the gas tank is to get constant pressure.
They will be needed if there is a bad designed gas tank, the 747 gas tank has no problems with size or pressure, so you will not need them.
I use Keep-on engines with no filters at all. And have good run time (over 5 minutes) and the presure is stable (engine doesn't get lean or rich at all).
Walter Diaz
Tags
rc-world, serpent, serpent 747, toy fair
