Old 12-06-2012, 09:26 AM   #286
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Thybaut View Post
I was already searching for it, took me a while.
When you print the attachment on A4 paper it should be the correct size, let me know if it isn't.
Not sure i have any A4 paper. Here in the states we use letter size which is 216mmx279mm. I believe A4 is 210x297
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 12-06-2012, 10:01 AM   #287
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
So who's gonna make us some?
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 12-06-2012, 05:24 PM   #288
lil-bump's Avatar
Trader Rating: 83 (100%+)
I don't know, never weighed the unmodified one.
The stock 1st gear one-way is 8 grams.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-07-2012, 03:03 AM   #289
Thybaut's Avatar
I modified it to letter size.
I will weigh it when I get home.
Serpent 733 TE | RB Touring 9, Novarossi N12T1 | Sav÷x SC-1257TG | Ko Propo EX-10 EURUS
Thybaut is offline   Reply With Quote
Old 12-07-2012, 06:14 AM   #290
Thybaut's Avatar
Pass you soon...
Modified it's 5/6 grams.
Old 12-07-2012, 04:42 PM   #291
lil-bump's Avatar
Kool.... thanks for the info.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-07-2012, 04:42 PM   #292
lil-bump's Avatar
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-14-2012, 08:10 AM   #293
Flywheel stopper and small 3mm wrench.
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-imag0413.jpg   Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-imag0415.jpg   Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-imag0420.jpg
Billy_Cheah is offline   Reply With Quote
Old 12-16-2012, 10:34 PM   #294
JamesHealey's Avatar
Whats the point in the fly wheel stopper?
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 12-17-2012, 05:37 AM   #295
nitrobeast's Avatar
Anybody find replacement screws for the diff? I stripped one and looks like i have to order diff case to get screws.
Rui Goncalves
Old 12-17-2012, 07:00 AM   #296
It helps a lot when I grease the trust bearing and to tighten the screw.
Old 12-17-2012, 08:12 AM   #297
I just put a flat head screw driver in.. good idea though!
Old 12-17-2012, 08:34 AM   #298
lil-bump's Avatar
A 5.8 flat head screwdriver works great.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-17-2012, 09:09 AM   #299
lil-bump's Avatar
New screws only come with a new diff case. I believe the best phillips screwdriver to use on these screws is a 4.0 phillips. Anything smaller will strip the head of the screw. I have one screwdriver in my toolbox that fits these screws perfectly but it is not an RC tool so I'm not sure of the size.
Another thing you should check; is make sure these same screws pass thru the rear pulley holes with ease. I've found that the holes in the rear pulley are slightly under sized which can give you false sense of how tight the diff halves actually are. I drilled out the holes to be slightly bigger. Be careful there is not much room for error.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-17-2012, 09:53 AM   #300
serpentamerica's Avatar
Pass you soon...
Pass you soon...
The part number for the screw is SER110173.. In stock
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: [email protected]
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
