Old 11-24-2012, 08:14 PM   #271
Team Chump's Avatar
Originally Posted by Michael_T View Post
Anyone have any issues lining up a Nova Keep On 100%?
I can't put any more shims behind the cone, as I will not have enough gap left to play with.
But it looks like 1st/2nd gear spurs are spaced alittle wider than 1st/2nd gear pinions - there seems to be an excessive gap between the spur gears.
Pinions are on correctly - just to confirm, the 1st gear pinion number faces outwards, whilst the 2nd gear pinion number faces the engine.
Try turning your 2nd gear pinion around so the numbers on both face outwards, gives a slightly wider spacing on the pinions.
Also check the one way bearing is pressed in properly in 1st gear housing, have had one that wasn't quite right.......
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-dsc_0048.jpg
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Team Chump is offline   Reply With Quote
Old 11-24-2012, 08:57 PM   #272
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i just checked the space between my pinions, and it does seem like M T's gap is much less. so i think you are correct he has 2nd pinion backwards. ??
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-25-2012, 02:44 AM   #273
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Thanks guys,
Pretty sure the manual states that first pinion number faces out, and second faces inwards towards the engine. I did try having both facing out, but the thrust holder and bearing doesn't quiet fit correctly.
All fixed now. I just drilled out the engine mount alittle, which allowed me to move the engine outwards slightly more.
Cheers.
Michael_T is offline   Reply With Quote
Old 11-26-2012, 03:29 PM   #274
NikoRacing's Avatar
Hi to all! the last week it was the first for me with the 747 and I was really happy with it
Fast lap times and zero problems!
But now the rain is on and the game is over ...I was looking if there is some ways to make the trasmission of the car lighter..
...like lightweight 2 speed and middle shafts and so.
I hope you can help me
Thanks in advance
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 11-27-2012, 06:04 AM   #275
Thybaut's Avatar
Thanks in advance
I modified the 2-speed flange and use titanium bolts.
Serpent 733 TE | RB Touring 9, Novarossi N12T1 | Sav÷x SC-1257TG | Ko Propo EX-10 EURUS
Thybaut is offline   Reply With Quote
Old 11-29-2012, 05:34 AM   #276
nitrobeast's Avatar
Trader Rating: 41 (100%+)
What receiver box is that?
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 11-29-2012, 11:12 AM   #277
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Nice work
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 11-29-2012, 06:22 PM   #278
Team Chump's Avatar
Serpent part #802151. Think it might be a discontinued item now, but there are still some floating around....
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Old 12-05-2012, 10:54 AM   #279
nitrobeast's Avatar
That looks really good!
Thanks! ill look
Rui Goncalves
Old 12-05-2012, 07:30 PM   #280
lil-bump's Avatar
Trader Rating: 83 (100%+)
Nice work... How much weight savings?
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-06-2012, 02:04 AM   #281
Thybaut's Avatar
I don't know, never weighed the unmodified one.
Old 12-06-2012, 05:25 AM   #282
nitrobeast's Avatar
Have you ran it? Wondering how well balanced it is now.
Rui Goncalves
Old 12-06-2012, 05:32 AM   #283
Thybaut's Avatar
I ran it last season, the balance is no problem. I made a template in Autodesk Inventor so i could cut it correct.
Old 12-06-2012, 08:00 AM   #284
nitrobeast's Avatar
AHHH, see i knew it looked really symmetrical to be cut by eye
You know what my next questions is?? Can we get that file!!!
Rui Goncalves
Old 12-06-2012, 08:22 AM   #285
Thybaut's Avatar
I was already searching for it, took me a while.
When you print the attachment on A4 paper it should be the correct size, let me know if it isn't.
Tags
rc-world, serpent, serpent 747, toy fair
