Old 07-30-2012, 07:36 AM   #196
lil-bump's Avatar
Trader Rating: 83 (100%+)
I'm not sure I would like the force applied to the bumber to be transfered to the rest of the car. The bumper is designed to absorb the force not transfer it. But I do agree this car ROCKS
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 07-30-2012, 04:50 PM   #197
Aza088's Avatar
Pass you soon...
There is actually no force applied to the rest of the car. it is quite flexible when pushed up and even a little flexible when bent down but it returns back to the original position.
Ill explain some history on why i decided to come up with this concept.
First race meeting with the 747 leading comfortably hit the inside of the ripple strip straight away i noticed a lack of steering in 1 direction the other direction was fine. Thinking i broke something we checked but the only thing was the bumper scraping on the ground on 1 side. Why this effects the steering it takes weight off that wheel made the can feel hard to drive and not consistent so holding the bumper off the ground was the answer it is also adjustable if you are worried about force transfer to the rest of the car.
But this is my 2 cents I'm not trying to sell it to you if you don't like it don;t use it.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 07-30-2012, 08:10 PM   #198
lil-bump's Avatar
No Problem.... keep it up. 1/8 scales have been using this style bumper for a very long time without any support mechanisms. I see no need to re-invent the wheel. this is why I have 2 extra lower bumbers. But if this works for you then go for it. I''ll make a small wager that other 1/10 cars will start using this style of bumper
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 07-30-2012, 08:30 PM   #199
Aza088's Avatar
Pass you soon...
same as the 1/8 yes and my 966 has the same style of support my 747.
i'd rather have good steering throughout the whole race.
Simple physics plastic rubs on ground = less weight = less steering
I can change the front bumper every run or add some support i chose some support.
Just my 2 cents if you think it doesn't work before you have tried..... well.
Good luck with your racing.
www.bluerc.net
www.hootrc.com.au
Old 08-01-2012, 11:16 PM   #200
AngryRog's Avatar
Trader Rating: 20 (100%+)
Hmmm...
Reminds me of the old days of 1/10th
Anger, K-Speed, Mini Mafia, NitroHouse.com
M03.1, M05v2 Pro, M05v2-R, M07, FF03-R, TA05v2, TRF419X, Roche P12
AngryRog is offline   Reply With Quote
Old 08-05-2012, 03:03 PM   #201
KweetNiet's Avatar
I've notice that the side stiffner (from 2speed axle to radio plate) is not on the 747. Does anybody know the reason for that, or did anybody tried the stiffner as on the 733TE?
Just wondering why it is not there anymore, and why or what should/could be a reason to put one on again.
KweetNiet is offline   Reply With Quote
Old 08-07-2012, 07:06 PM   #202
blanks596's Avatar
Trader Rating: 14 (100%+)
If you want the side stiffener for the rear end, you can purchase the option kit for that. It's just a another tuning option
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 08-07-2012, 08:25 PM   #203
lil-bump's Avatar
The chassis for the 747 is actually stiffer than the 733. Hence no side brace.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-15-2012, 05:38 PM   #204
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
After looking at all the positive comments regarding the new SERPENT 747 I finally had the chance to run mine for the first time last weekend at the XRAY Challenge in LA.
The car was great out of the box. It was really easy to drive. Great corner speed and acceleration with the new clutch. This is the best car I have driven so far.
Walter Diaz
wad is offline   Reply With Quote
Old 08-15-2012, 10:42 PM   #205
blanks596's Avatar
You forgot to mention that you took home the gold
Max S
Old 08-16-2012, 05:38 PM   #206
wad
wad's Avatar
Yes, small detail... I won the race, it was my first time with the car, so I couldn't ask for anything better....
Walter Diaz
Old 08-17-2012, 01:29 PM   #207
gearhead_22's Avatar
Send a message via AIM to gearhead_22
747 gettin better and better
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 08-21-2012, 11:13 AM   #208
PNT2000's Avatar
bad ass car..
PNT2000 is offline   Reply With Quote
Old 08-23-2012, 04:21 PM   #209
tha Beast's Avatar
Trader Rating: 100 (99%+)
Originally Posted by AngryRog View Post
Hmmm...
I'm really thinking about doing this to my car as well do any of you guys know where to find the parts to make it happen any help I'd really appreciate thanks
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
tha Beast is offline   Reply With Quote
Old 08-25-2012, 04:02 AM   #210
Pattojnr's Avatar
Trader Rating: 19 (100%+)
well i just got my bodies painted and mounted. i just weighed the car ! 1655grams. looks like i got a fair bit of weight to add. untill our rules change, we are still running on the 1725 gram rule. and i have big tyres on it.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
