Old 09-27-2014, 02:08 AM   #421
Bundy_Bear's Avatar
Originally Posted by afm View Post
I have 2 R10 running foer 2 years now, and the car is great it is as fast as any top Brand cars in the market. Main problema is getting spares, and about the issue of stripping gears, it strts happening when the plastic inserts on the transmission axle develop play with the aluminum support and or the bearings...as son as it starts to do so change plastic inserts and bearigs and on assembly put some loctite aroud plastic insert before pīlacing them on aluminum support.
AFM
AFM: Thanks, we had already replaced the bulkheads and plastic inserts as well as the chassis, but we still has issues. This week we replaced the 2 speed shaft and one way bearing, however we failed to finish the final due to further radio issues.
BJames: Richard has always run the receiver in the original spot, we have issues but continued as best we could. Again we have had issues and it is looking more and more like they are heat related from the temperature of the exhaust and engine and the location of the receiver. Had similar issues with my G4 back in the days and it caused me to change cars. Richard is at that point now as it is costing us results by not finishing week after week.
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 10-02-2014, 10:25 PM   #422
I have 2 r10 cars, 1 is setup and the other is spares. I never have issues getting parts for it at all as my lhs stocks all parts. I do have a tendency to strip spur gears even with a correct setup. I'm not sure if it's a heat issue melting them maybe or could be little rocks.. I don't know.
The 2speed is terrible and I had very inconsistent gear changes so I used and xray 2speed. I'm about to order front and rear Capricorn Kevlar diffs as I find the stock ones leak. I'm also using a set of the rear springs on the front as they are a bit softer and it seems to work for me. I love this car and I'm continuing to get faster and faster with it. I would be interested in reading people's setups and changes they have made.
WSWanderers is offline   Reply With Quote
Old 10-03-2014, 06:43 PM   #423
Woow...Cool man..I want buy like that..
dion900 is offline   Reply With Quote
Old 10-04-2014, 09:21 PM   #424
bjames's Avatar
Trader Rating: 24 (100%+)
I got my car in a trade along with some other stuff so its used but it appears to me that it has mugen gears on the two speed. I'll be getting it out for a little testing tomorrow but it will be mostly breaking in the new engine and not much racing.
-Brian James-
bjames is offline   Reply With Quote
Old 10-07-2014, 07:40 PM   #425
Bundy_Bear's Avatar
We have been running Andy Moore's setup from the 2012 Worlds in Thailand at England Park at Brendale in Brisbane. Hot Bodies use to have to available to download on their website,but it has all disappeared now and HPI doesn't list much at all.
MissMooRC Racing
Old 10-08-2014, 08:52 PM   #426
bjames's Avatar
Did a brief test run with the car today and I have to say that I am very pleased so far. Hopefully get to race this weekend. Moo, can you post the andy moore setup if you know it?
-Brian James-
Old 10-09-2014, 03:55 AM   #427
Bundy_Bear's Avatar
Default Andy Moore Setup!
Bjames:
Front:
Shock Tower Position: 4
Roll Centre (Top): 1
Droop: 1mm
Castor: 1mm
Camber: -1 degree each side
Toe: +1 degree each side
Sway Bar: Flat
Ackerman: 0mm
Shock Piston: 2
Shock Oil: 600wt
Spring: Ride Yellow
Diff Oil: Ride Putty 45
Rear:
Shock Tower: 5
Roll Centre (Bottom Arms): 5
Roll Centre (Top Inner): 3
Hub Spacer: 3mm & position 1
Sway bar: 2.1mm
Diff Oil: 60,000wt
Shock Oil: 800wt
Shock Spring: Ride Blue
Shock Piston: 2
Droop: 4mm
Camber: -1 degree (each side)
Toe: -3 degrees (each side)
Wheel Base: Long
MissMooRC Racing
Old 10-09-2014, 05:09 PM   #428
bjames's Avatar
Thanks! Can't wait to get some more time on the car. Box setup felt pretty good but always nice to see what the team drivers are doing.
-Brian James-
Old 08-25-2015, 04:42 PM   #429
R2D2Mares's Avatar
I had problems to find the optional 2nd Pinion Gears 22T/23T and the 2ND Spur Gear 53T (in US and Mexico).
Anyone knows if there is a compatible part (XRay/Capricorn/etc.)
R2D2Mares is offline   Reply With Quote
Old 08-25-2015, 05:34 PM   #430
afm
afm's Avatar
XRAY spurs are compatible fully compatible....i donīt know if pinions i think you need to use XRAY clutch bell. also all the belts from XRAY are compatible.
regards
AFM
afm is offline   Reply With Quote
Old 08-27-2015, 12:39 PM   #431
R2D2Mares's Avatar
regards
AFM
Thanks ... the HB belts are very expensive... good to know.
______________________________________________________________________________
Hot Bodies R10 : OS Max 12TZ EB Mod : RB Speed .12 : Picco TORQUE .12 TOURING EMX-WC
HPI RS4 EVO 3 : HPI T3.0
Old 08-28-2015, 10:06 AM   #432
try KM racing,it from same factory
kyosho malaysia is offline   Reply With Quote
Old 08-29-2015, 03:50 AM   #433
Bundy_Bear's Avatar
Buy belts from Tough Racing, less expensive and very good quality
Old 03-30-2016, 06:47 AM   #434
BJR
Trader Rating: 17 (100%+)
Hi guys
I'm new to the nitro scene and have picked myself up a HB R10 kit just the other day.
I have finished building the kit and it was pretty straight forward. I have come across a problem though and I don't really understand what's making this happen...
The right side front arm wont move up and down freely, at first I thought it was a shock problem, then thought maybe something to do with the sway bar setup but it is none of the above. I have pulled the front end down to have a closer look and realised that the arm moves freely until I put the upper arm (108570) on the hinge pin then all of a sudden the arm won't move upwards... Any suggestions? Maybe I have done something wrong..
Your help is appreciated
Blen
BJR is offline   Reply With Quote
Old 03-30-2016, 08:03 AM   #435
lil-bump's Avatar
Trader Rating: 83 (100%+)
How much camber do you have on this side of the car? Is the front drive shaft bottoming out into the diff out drive cup?
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
rc crawler 2.2 savageboy69 R/C Items: For Sale/Trade 15 12-27-2009 11:34 PM
