Old 04-01-2013, 05:42 PM   #181
Bundy_Bear's Avatar
Originally Posted by KMW View Post
It sounds like one of your front steering hubs might be upside down. If you look closely at them you'll see that there's an extended "lip" on one of the areas where the pivot ball comes out. That extended lip needs to be on the top of the suspension, or else it will limit movement. You can see how it's supposed to be installed in the side diagram of Step C-03 on page 9 (look where it says "2mm").
Thank you i will check this... to be honest i was under the impression that the hubs were interchangable and therefore reducing the amount of spares required.
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 04-01-2013, 08:10 PM   #182
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Originally Posted by performula View Post
If its anything like the R40 buy something else. That was the most fragile car ever.
i put my R40 on the treadmill for a while
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 04-01-2013, 08:59 PM   #183
Bundy_Bear's Avatar
KMW: You where correct the hubs were upside down, it is hard to pick up on the recessed part for the carbon fibre bit to screw down onto
We now have a stripped out pivot ball, anyone got an idea how to get it out of the arm now so we can reuse the arm and hub?
Thanks in advance...
MissMooRC Racing
Old 04-02-2013, 01:04 AM   #184
Bundy_Bear's Avatar
Originally Posted by TAMAK View Post
OFNA JLR starter box is the best bang for the buck!
My question is does it work for sure with the R10? It has a really small cut out around the flywheel...
MissMooRC Racing
Old 04-02-2013, 05:13 AM   #185
Bundy_Bear's Avatar
Originally Posted by Ec1 View Post
Sorry Bundy_Bear, thanks for the help.
I discovered yesterday that the Xray pullies didnt fit, they are too wide so the c-clip cant be mounted. so we need a new middleshaft and rear 2speed shaft, but as said i cant find any that fits the car
KM has a lot of parts that fits the car thou.........
All good...
Question, I am pretty sure the pinions, spurs and diffs are the same do you know of anything else?
Thanks in advance!
MissMooRC Racing
Old 04-02-2013, 06:28 AM   #186
TAMAK's Avatar
Trader Rating: 28 (100%+)
The JLR box is made specifically for Nitro sedan, I know the wheel on mine is a smaller diameter and thinner wheel than my Ofna compact silver top. You have to make sure that the tip of the wheel aligns with the tip of the flywheel, you should be golden. . I have a NT1, so I dont know if it will work for the R10 specifically But, you are right, the cutout is small! Worst case is dremel..
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 04-02-2013, 07:48 AM   #187
Ec1
Ec1's Avatar
Bundy_Bear, Front axles, rear axles, plastic 20t pulley on the 2speed shaft, f+R Diffs all 2speed gear.
You can also use the MTX-5 alu piwotballs.
My build blog (in swedish): http://rsb.se/arena/showthread.php?7...ge-2013-HB-R10
// Roland Strom
Ec1 is offline   Reply With Quote
Old 04-02-2013, 10:55 AM   #188
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
// Roland Strom
You do know that ur going to get fuel in your receiver right If I were u I would put it in a balloon if ur going to mount it there! Just a thought, hate to see a new car have a run away the 1st day at the track, I don't think hara,Andy,or leenu put there receiver there
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 04-02-2013, 11:44 AM   #189
Ec1
Ec1's Avatar
No problem, had several cars with the thereciver in that place. The receiver Will be full of vaselin and then wrapped in a ballon.
Old 04-02-2013, 05:23 PM   #190
Bundy_Bear's Avatar
Thanks, my brother has ordered one and will see if it works when it arrives. So far have tried the Team Associated/Thunder Tiger & Mugen box. Otherwise we will have to break out the dremel
MissMooRC Racing
Old 04-02-2013, 05:25 PM   #191
Bundy_Bear's Avatar
// Roland Strom
Thanks Roland, i thought the KM universals where a different length to the HotBodies ones... The black ones included in the R10 kit remind me of the R40 ones from all those years ago
It would be good if you could show some photos with these parts on the car!
MissMooRC Racing
Old 04-02-2013, 05:29 PM   #192
Bundy_Bear's Avatar
And how is a Kyosho, Capricorn, Serpent or a Shepherd any different with it sitting out on the other side waiting for someone to t bone it causing a run away? As far as i am concerned only Xray, Mugen and KM got it right with a plastic box included standard.
MissMooRC Racing
Old 04-02-2013, 05:36 PM   #193
jordan860's Avatar
nice
jordan860 is offline   Reply With Quote
Old 04-02-2013, 07:20 PM   #194
Trader Rating: 65 (100%+)
What about the extremely hot pipe sitting right there as well? Won't that be a major issue?
goose510 is offline   Reply With Quote
Old 04-02-2013, 08:51 PM   #195
Bundy_Bear's Avatar
Will have to wait and see, my brother has added some heat relective tape to the side of the plastic brace in an attempt to reflect heat from the exhaust. However the original HPI R40 had it in the same spot but in an enclosed box and i don't remember having issues. I did have heat related issues with receiver on my Team Magic G4S that sat in front of the engine under the fuel tank.
MissMooRC Racing
rc crawler 2.2 savageboy69 R/C Items: For Sale/Trade 15 12-27-2009 11:34 PM
