Old 01-05-2005, 01:47 AM   #16
ziggy12345's Avatar
Originally posted by sook
Does anyone on this forum know of anyone that has tried to run the same 26 or 28mm front shore rated foam tire on all four corners? Any pros or cons of what you have witnessed?
26mm all round. Itried. Less grip on the back. works well on the FW-05 as it needs a bit more steering
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 01-05-2005, 01:51 AM   #17
ziggy12345's Avatar
Tyres (correct spelling!) have a large amount of moisture in them and as mentioned if they dry out will crack and chunck very easy.
Putting them in a bag under vacuum will make the problem worse as it will suck out the moisture.
Although i have never tried you could store them in a bag of distilled water! Then dry them off before a race!! LOL..
Sponsored by:
Norfolk and Chance
Old 01-05-2005, 10:48 AM   #18
Thanks Ziggy, I kinda thought that was the case with the same mm tire all around. I am going to try using this method this racing season. If anyone else would like to share this experience, let me know how it worked for you.
ss
sook is offline   Reply With Quote
Old 01-05-2005, 12:13 PM   #19
kidDynomite's Avatar
I used to keep my cigars in a bag that was within a ziplock bag that had a napkin soaked with distilled water (tap water will create mold). It works. So do you think a cheap humidor box will work too?
kidDynomite is offline   Reply With Quote
Old 01-05-2005, 03:46 PM   #20
macnkitty2002's Avatar
ziggy, tyres is the correct overseas spelling. In the u.s., they are spelled tires. humidor box is a good idea, or i've heard that some medical vapor rubs are good if you put some in a film canister with holes poked in the top. put the canister inside of your sealed bag. i dont trust that though
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 01-05-2005, 07:32 PM   #21
Trader Rating: 15 (100%+)
The front and rear rubber compounds are differant in the same shore rating number. The fronts are skinner then the rears. The front tires have alot more rubber then the rears in the same shore number. I would think that if you put 28mm front tires with the same shore number in the front and rear that it would be very loose in the rear.
THE DOCTOR is offline   Reply With Quote
Old 01-06-2005, 01:57 AM   #22
ziggy12345's Avatar
Sato Seiki make 28mm rears with a different compound to the fronts. They work great
Cheers
Sponsored by:
Norfolk and Chance
Old 01-07-2005, 05:45 PM   #23
tenderfoot57's Avatar
Send a message via AIM to tenderfoot57 Send a message via Yahoo to tenderfoot57
Originally posted by macnkitty2002
is that 30 or 32 shore or mm?
That is shore rating. Wild huh. I got them free from a friend that was getting out of rc.
tenderfoot57 is offline   Reply With Quote
Old 01-07-2005, 06:18 PM   #24
never heard 32 shore, only 30 or 35, nothing in between.
Losi Rock Rey
Old 01-07-2005, 07:01 PM   #25
Sow&Steady's Avatar
Actually there is such a thing as 32 shore, depends on the brand but at the end of the day these ratings are ball-park numbers. The best way to really check is by using one of those meters (durometer I think ... measures foam shores).
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-07-2005, 09:07 PM   #26
can a "durometer" be purchased at a hardware store?
Losi Rock Rey
Old 01-12-2005, 09:01 PM   #27
No, Nascar uses them and probably all types of auto racing. The only thing that I have found out is that you can get differant readings on the edge of the tire and from the center of the tire. If the tire is new 62mm or after the same tire is worn down 56mm.
Foam tyre sell out s.nicholson Australia For Sale/Trade 5 02-03-2008 05:18 AM
ATS Foam Tyre?? initialrays Nitro On-Road 8 09-22-2007 07:20 AM
ZAC, Kyosho, ATS Foam Tyre Sale Rody Australia For Sale/Trade 2 04-17-2007 01:44 AM
Foam tyre manufactures ioxqq Nitro On-Road 16 04-13-2007 10:47 AM
1/10th GP Foam Tyre UFShadow Malaysian R/C Racers 12 07-20-2006 09:37 PM
