What foam tires fit HPI RS4 >
Old 01-22-2012, 08:46 AM
Default What foam tires fit HPI RS4
Hello all,I have an RS4 3 EVO and I would like to try some foam tires.Can anyone tell me what works/fits and what to stay away from?
MCHPI is offline
Old 01-22-2012, 10:00 AM
bluer322's Avatar
Try Contact tires you can buy them at kevcoracing.com. Try 37 front 40 rear.
bluer322 is offline
Old 01-22-2012, 10:41 AM
Thank you!
MCHPI is offline
Old 01-22-2012, 11:19 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
Any TC foam should fit. Conatct, Jaco, Matrix, Capricorn, GRP, etc., etc.
wingracer is offline
Old 01-22-2012, 11:28 AM
DS Motorsport's Avatar
On the left rear you might have to grind a little material of the radio box in order to make the 30mm wide tires fit.
DS Motorsport is offline
Old 01-22-2012, 02:48 PM
Or use the fronts (26mm's) all around.
modelfan is offline
Old 01-22-2012, 05:16 PM
wingracer's Avatar
Front rubber is different from rear rubber. The car would have no rear grip.
Old 01-22-2012, 05:26 PM
Grip is created/assisted by the shore rating. So the rear 26's should be a different shore than the front 26's according to running conditions.
Don't forget, this car originally comes with rubbers all around, not foams. And they are 26mm's.
modelfan is offline
Old 01-22-2012, 05:32 PM
No, wingracer is right. Even if you run a different shore the make up of the rubber used in front tires is defferent to the one used for rear tires. Front tires dont work on the back, and vicerversa.
nitrodude is offline
Old 01-22-2012, 05:57 PM
You want 26mm tires on the front and 30mm ones on the rear. The RS4 was my first rc car and running 26mm tires in the rear makes it have a lot of oversteer.
So you could either grind some material from the radio box, use thicker rear hexes to increase offset or get rims with more offset. Capricorn rear wheels have +0,85mm offset.
Old 01-22-2012, 06:07 PM
hitcharide1's Avatar
Default Best idea yet
I've got old Delta that I ran at club races and plan to run in the Midwest this year in pan class. But it's sort of hell getting foam, right? Since all you can buy anymore is the tire with foam on and no one makes that stuff for the vintage cars, nor does anyone sell just the foam. Long story short, I made a bunch of phone calls and I have a company lined up to sell me foam that I'll then cut into disks just like "back in the day" and sell. Looks like I'll have 35, 40 and about 45 shore to work with since the foam company doesn't operate in "shore", just poundage, so I've had to convert and modify and blah blah. I'm also going to make combos since I'm running 4 wheel drive as well and think I can get around this having to run one thing up front and another in the rear to make it all balance out (another old trick.) I should be up and running by mid march and I'm hoping to sell foam for about 3-4 bucks a tire, which'll cover the foam, shipping and handling, and a nickle or two besides for my time...either way it beats 20 bucks a pair for 1/8 tires (which is highway robbery if you ask me.) I know some guys with $$ to burn will probably prefer to do it the way it is now, but that doesn't help guys like me who either need foam for the vintage or just want to race without going broke on tires. There was a guy at the GLC last year with $600 in tires...that's just insane! Anyhow, anyone interested get with me, I'm a tad slow to respond sometimes but anyone needing foam for vintage I'll put at the head of the list when I get up and going, I'll be selling it in rings just like it used to be so anyone who plans to go this route will need to fabricate a shoe horn and buy some glue....all the best....
hitcharide1 is offline
