Old 01-20-2012, 10:34 AM   #1
Trader Rating: 58 (100%+)
Smile Needed help!!!!
Here is my problem, I tried to unscrew the head hex screw on the engine mount on bottom of the chassi, but I accidentally striped the head of its screws and now it's going round and round like circle. Anyone, know how or anyway to unscrew it? Any though or help would much appreciated, thanks. The screws kinda tight...
Skaidragon is offline   Reply With Quote
Old 01-20-2012, 11:01 AM   #2
dj apolaro's Avatar
Dremel a slot in the head so that you can use a thick flat head screw driver. Make sure you dremel the head of the screw as deep as possible without taken the head off.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 01-20-2012, 11:17 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
It is a countersink screw. I would drill the head off. If it is an M4 screw use a 4.5 or 5mm drill, dril in the middle of the screw until the head comes off. Probably you can unsrew the rest of the screw with your fingers or else when you have taken out the mount use the dremel to make a slot as DJ mentioned.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-20-2012, 12:26 PM   #4
kmh
Dremel Tool w/cutting wheel
kmh is offline   Reply With Quote
