Old 01-18-2012, 10:20 AM   #1
Default How efficient is a 2spd tranny.
Say you rc Gurus there are 2 designs of 2 speed tranny the pawl design and the cluthshoe design. Based on lockup at engament I would rate the pawl at 100% efficient and the clutchshoe type at 97%-98% Whats your opinion??
nitrohead5300 is offline   Reply With Quote
Old 01-18-2012, 12:56 PM   #2
lil-bump's Avatar
Trader Rating: 83 (100%+)
I don't want to get too far into this. But I would say the shoe design would be more efficient. In a shoe design you have more surface contact area and where as in a paw design your only contact area would be where paw touches the 2nd speed gear holder.
Some paw designed 2 speed's there was only one paw. So Depending on when the paw engaged you might have to wait one complete revolution of the holder until the paw would engage the holder, a clutch shoe design does not have to wait.
Pass you soon...
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-18-2012, 01:01 PM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
The clutch shoe type comes in with a small moment of slip keepng the gears more alive when switching to 2nd gear.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-18-2012, 01:24 PM   #4
.............Roelof would you rate the effciency of the clutch style 2 speed at about 97% ?? Roelof I am wanting to build a 2 speed for 1/5 scale Onroad.
Old 01-18-2012, 02:34 PM   #5
lil-bump's Avatar
I would not worry about efficiency unless your drag racing. I would be more concerned with how much torque is going to applied to the drivetrain when 2nd gear engages.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 01-18-2012, 03:05 PM   #6
Roelof's Avatar
In the past FG had a 2-speed and if I am right it was based on a lever hooking into the 2nd gear adapter. I think it is the better choice to get it right within the RPM range you have.
Old 01-18-2012, 03:13 PM   #7
wingracer's Avatar
Trader Rating: 24 (100%+)
I find that the shoes don't really wear much so they aren't slipping very much. It seems like there is just a bit of slip on engagement (which is good for stability and reduction of wheelspin) but after that it might as well be locked up. I feel it is a much better design than the old lever style.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-18-2012, 03:17 PM   #8
DS Motorsport's Avatar
Originally Posted by wingracer View Post
I find that the shoes don't really wear much so they aren't slipping very much. It seems like there is just a bit of slip on engagement (which is good for stability and reduction of wheelspin) but after that it might as well be locked up. I feel it is a much better design that the old lever style.
+1
It only slips slightly on engagement. If the shoe was slipping constantly it would wear out as fast as a slipping clutch shoe.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-18-2012, 04:14 PM   #9
The pawl design 2 spd is failing when combined with the higher hp modded gas engines. Thanks for your help DSMotorsport and wingracer. And everybody else who posted .
