Throttle stuck only when engine is running. >
Old 01-15-2012, 08:29 AM
Default Throttle stuck only when engine is running.
So I have a Thunder tiger VX and I'm having problems with the throttle. I amn the original owner and bought it new.
When the car is off all eletronics work fine and when I turn it on it works fine aswell but when I give it full throttle, the throttle gets stuck at full and won't go back. In order to get it back I have to either turn the engine off or have to manually push close the carb with my hands( it is stuck pretty hard like a and has a spring affect( if I only close it half way it keeps pushing open, but if I fully close it will stay there).
What I can't wrap my head around is when the engine is off the carb won't get stuck even if I close it hard with my hands and the problem only happens when at full throttle. So help me out guys.
Tylerpace is offline
Old 01-15-2012, 09:01 AM
Geezatec's Avatar
What Radio yuo useing?? EPA Adjust May fix the problem.
Geezatec is offline
Old 01-15-2012, 09:08 AM
I'm using the stock Jaguar T2P AM radio.
