Old 12-29-2004, 09:51 AM   #1
TRAJ's Avatar
Default Sato Seiki - Foam Tire
Hello all
can anyone give me any info one these tires? SATO SEIKI - FOAM TIRE
Is the compound made the same as Eleggi, Power, Fast, Twister ect etc?
Please help
Thanks!
TRAJ is offline   Reply With Quote
Old 12-29-2004, 10:08 AM   #2
Sow&Steady's Avatar
I've tried these before. They're reasonably priced but I find them inconsistent. you can use them for practising but I personally don't use them for races.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 12-29-2004, 10:15 AM   #3
blount's Avatar
I orderd some speedmind tyres form Hong Kong and they sent me those Sato Seiki and they where the worst tires I have ever ran and cost me the race in the winternats. Don't do it!!!
blount is offline   Reply With Quote
Old 12-29-2004, 07:15 PM   #4
nitrodude's Avatar
Strange, I bought a set of these to try and loved them. the wear is very good, and I felt I could go into corners faster. I thought htey were the same as the Mono tires, but I guess not. Im happy with them.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 12-29-2004, 07:54 PM   #5
InitialD's Avatar
I believe they are the same as the Monotuning tires. Sato Seiki rims and foam are made by Speedmind although if you compare the foam, the ones on the Sato Seiki are slightly harder than the Speedminds i.e. 37 on the Sato feels like 40 on the Speedmind dish tires.
Old 12-29-2004, 08:39 PM   #6
TRAJ's Avatar
Thanks for your imput guys
i guess ill just stick with speedmind for and extra .50c a rim a pair
Old 12-29-2004, 09:35 PM   #7
R/C Tech Charter Subscriber
Give Twister's a try. You will not be dissapointed. Tires are priced great and are very strong and consistent
www.twistertires.com
racinghobbies is offline   Reply With Quote
Old 12-29-2004, 10:19 PM   #8
TexasRacer's Avatar
Send a message via AIM to TexasRacer
Yea give those Twister Tires a try they are absolutley the best tires out there.
TexasRacer is offline   Reply With Quote
Old 12-29-2004, 11:23 PM   #9
TRAJ's Avatar
but they are nearly double
i get the speedmind for $8.75 for front and $8.25 for rears same with Eleggi, Power and fast tires
although the Twisters rim design is pretty cool!
Thanks anyway
Old 12-30-2004, 05:18 PM   #10
ziggy12345's Avatar
I used those Sato Seiki tyres and they are one of the best i have had. Very low wear and excelent grip. I still use the 28mm rears
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 12-30-2004, 05:36 PM   #11
TRAJ's Avatar
Hi ziggy!
so you would say that they perform just as good as ellegi or fast tires?
Old 12-31-2004, 02:50 AM   #12
ziggy12345's Avatar
Hi
I started a thread here to discuss all makes of foam tyres. The result was pretty mixed as some tyres perform on some tracks but not on others.
Mainly you have 2 typres of tyres. GRP rubber and JAP rubber. Ellegi, Power, Jaco and Fast along with a lot of others use GRP where Sato Seiki, Mono tuning (Rebadged sato Seiki) GQ and Speedming use JAP rubber (I'm sure this is not its technical name!)
GRP USUALLY! have high grip with high wear and also a tendancy to chunk at the edges where JAP have just as much grip on certain tracks and lower wear rate with less chunking.
Most tyres, GRP or JAP are made up of 3 rings of different compounds glued together to make the complete tyre. Yokomo (i think!) make a tyre where the rings are glued on top of each other and not next to each other and these are more expensive but i have heard very low wear and high grip.
In the end its what works on your track. I almost always use GQ 37s all round when out track is warm and dry. 40's in a longer final.
Cheers
Sponsored by:
Norfolk and Chance
Old 12-31-2004, 02:52 PM   #13
Send a message via Skype™ to JordanC
You guys should give the Zac's and Active tyres a go
JordanC is offline   Reply With Quote
Old 12-31-2004, 08:12 PM   #14
Team-RTR's Avatar
i have never had a better tyre then the zac project multi ring foam tyres. expensive but worth every penny.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 01-01-2005, 04:07 AM   #15
ziggy12345's Avatar
Are the rings layered or are they radial rings?
Cheers
Sponsored by:
Norfolk and Chance
Mugen MTX4 fully hop up Aluminum option stuff by Sato Seiki rccplayer R/C Items: For Sale/Trade 0 03-26-2007 01:14 PM
Anyone have a review of Sato Seiki foam tires? charlesd Nitro On-Road 4 03-05-2007 02:18 PM
WTT: mugen seiki II starter box (new in box) for tire truer or set up system tc3Guru R/C Items: For Sale/Trade 2 04-16-2005 11:41 PM
