Old 06-17-2002, 11:48 AM   #1
Default Identifying Mt-12 Turbo engine.
Hi, I just bought a used mt-12 engine. How do you identify if it is infact a true turbo other than by looking at the plug. Is there special lettering or different outside desgins?
Thanks.
rcpilot is offline   Reply With Quote
Old 06-17-2002, 12:11 PM   #2
Check to see if it has a turbo head button.
BallPy is offline   Reply With Quote
Old 06-17-2002, 12:29 PM   #3
It's got a turbo button, I can see that. But is there any other way to check it's a true turbo, because you can just take a stndard mt-12 and put in a turbo button but than it's not a true turbo because the internals are not that of a turbo.
Old 06-17-2002, 12:32 PM   #4
Pull the back plate off and check the crank. The crank should be way different looking than a standard crank. There should be a channel in the back of the crank.
Old 06-17-2002, 01:34 PM   #5
Thanks Ballpy
Need help identifying a chassis!! vrcoupe Electric On-Road 5 12-13-2007 05:15 AM
Help identifying a car. DangerDave Rookie Zone 3 05-25-2007 09:58 PM
Need help identifying and armature PWA Electric On-Road 9 05-11-2007 12:08 AM
Help Identifying cells? oMONSTERo Electric Off-Road 1 07-01-2006 04:38 AM
Need help identifying old Kyosho F1 RC car MJGunn Rookie Zone 0 01-11-2003 06:31 PM
