Old 12-27-2004, 03:46 AM   #1
asw7576's Avatar
Default Big Dent Pipes
I have tuned pipes turbo, and they are dented big time. One pipe get medium dent and another one get nice big dent. What do you do ?
1. throw it away ?
2. try to fix it, but how ?
3. don't care..... just drive and go.
thx man.
Old 12-27-2004, 03:55 AM   #2
thefuzzclub's Avatar
Default Re: Big Dent Pipes
1. throw it away ?
thx man.
you may put water in the pipe, of course put a stopper so that water will not spill. place it in the freezer overnight. the water will make your pipe expand. i tried it several times and it works
thefuzzclub is offline   Reply With Quote
Old 12-27-2004, 05:50 AM   #3
for best results do same as above but use milk, it expands better than water
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 12-27-2004, 06:18 AM   #4
jag
jag's Avatar
If you do try freezing it, don't leave it in overnight. Check on it at least every hour. If you don't it can split the pipe or expand it. This proceedure actually works very well but you need to watch it.
Good luck.
jag is offline   Reply With Quote
Old 12-27-2004, 09:59 AM   #5
InitialD's Avatar
Good luck.
You could leave it overnight... Just strap on some zip ties over the pipe to make sure it does not expand more than it should. Works great. No need for milk and everything.
Old 12-27-2004, 10:47 AM   #6
Hello, I've got a small dent somewhere near the joints, will it affect performance or tuning? thanks
baldwinn is offline   Reply With Quote
Old 12-27-2004, 10:59 AM   #7
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
My opinion only, as long as it is not dent in the chamber area you should be fine,
Ah10 is offline   Reply With Quote
Old 12-27-2004, 11:18 AM   #8
Hello Ah10, thanks for the reply!
Old 12-27-2004, 03:51 PM   #9
Ah10's Avatar
you are very welcome but like i said, it is just my opinion, dont even know if it is the correct answer for you!
But I have driven with a dent pipe, not that bad and not in the chamber area and i just pop it back out, and I dont seen any decrease or improvments.
Old 12-27-2004, 11:17 PM   #10
asw7576's Avatar
Okay, the water technic has been done and it improved little bit. The pipes are slightly bigger, i think .......... So I get crazy idea to drill another hole through the exhaust tip.
( If you look at inside the pipe from manifold side, originally there are four holes. I add another hole by drilling it through exhaust tip ).
I'll give you the report how does it affect performance.
Pipes!! InsaneRC R/C Items: Wanted to Buy 3 02-09-2008 07:44 PM
Best pipes for an OS RG Cain Electric Off-Road 2 02-24-2007 08:20 PM
repair your dent exhaust pipes fredrick5 Nitro On-Road 20 01-17-2007 11:22 PM
Pipes? Robster Electric Off-Road 2 07-15-2003 01:17 AM
In-line pipes versus old style pipes for .12 engines Hammer0412 Nitro On-Road 25 07-18-2002 12:19 AM
