Old 11-12-2002, 08:09 PM   #121
Yep,
I made a smaller unit and lighter then the Serpent/Neo unit
Works pretty good too!!!
smitty is offline   Reply With Quote
Old 11-12-2002, 11:06 PM   #122
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
I'm running smitty's new 2 speed setup also. In fact, had my GT4 at the track a little over a week ago. Worked flawlessly and has butter smooth shifting!
Dan is offline   Reply With Quote
Old 11-15-2002, 12:25 PM   #123
kaikiok's Avatar
Default yokomo new centax clutch
anyone of you installed the new centax clutch?
I just bought one and having problem installing it to my
OS TR sg-shaft engine...
I follows the given diagram (since i dont understand japanese I just figure out from the picture), but no matter how I arrange the given shims, I end up having a locked clucth.
Is there any site or diagram that i can refers to apart from the japanese version?
kaikiok is offline   Reply With Quote
Old 11-15-2002, 08:07 PM   #124
Kaikok
Please let me know when you figure that out.I just got my centax and I having the same problem.
PRO RS4 is offline   Reply With Quote
Old 11-15-2002, 08:20 PM   #125
asd
Send a message via ICQ to asd
there should be about .5-1mm of freeplay between the cap screw that holds the clutch assemblly toghether and the shims and thrust bearings, hope this helps
asd is offline   Reply With Quote
Old 11-15-2002, 08:41 PM   #126
So I don't have to tight the cap srew all the way in?
Old 11-15-2002, 08:48 PM   #127
well, we all knew somebody was going to ask it......MTX-3 vs GT4 Pro
throw in the 705 if you would like.....which one.....in a balls out, nothin to lose fight to the finish.....(is this battle bots or touring cars)
Nytrochaos is offline   Reply With Quote
Old 11-15-2002, 09:23 PM   #128
Dan
Dan's Avatar
Check out www.yokomousa.com
You'll need to email Paul because some of the early Centax kits came with japanese instructions. He can email you the english instructions.
Old 11-15-2002, 09:26 PM   #129
asd
no, u'r not supposed to tighten the srew all teh way, there NEEDS to be alil bit of freeplay
Old 11-15-2002, 09:40 PM   #130
kaikiok's Avatar
Default yokomo new centax - solved
I manage to install the centax unit with bout 0.5mm clearence with the cap screw tighthened. I found out that I didnt hv enough shaft spacing in the 1st installation coz of the thicker cone washer. Once I change to a thinner cone washer (where u slot in the flywheel) I manage to install it according to the diagram.
I gonna test out this unit tonight... tired of cutting clutch shoes...
hehe
Old 11-15-2002, 11:28 PM   #131
acs
acs's Avatar
The Yokomo clutch looks similair to the Kawahara clutch. I have the Kawahara clutch. It was a huge improvement to the accelaration of the car. I'm sure after your first run with the clutch you will have a huge smile on your face.
The improvement was good enough to TQ and win the final.
acs is offline   Reply With Quote
Old 11-19-2002, 04:04 AM   #132
Dan: How can you tell that if you are putting enough Yokomo hard diff oil for the front gear diff unit and the medium diff oil for the rear diff unit??
How does front and rear diff unit feel? Harder to rotate for the front? Any tips for correct setup of the front & rear diff units???
Thanks.
MIKA is offline   Reply With Quote
Old 11-19-2002, 09:07 AM   #133
CSF0623's Avatar
MIka: fill the diff housings to the top!
CSF0623 is offline   Reply With Quote
Old 11-19-2002, 11:45 AM   #134
nitrodude's Avatar
made a floating body mount for the Yok Gt4. I will try to post pictures, if they don't show e-mail me for them and for imformation to [email protected].
Thanls,
Steven Muller
nitrodude is offline   Reply With Quote
Old 11-19-2002, 11:47 AM   #135
nitrodude's Avatar
another one
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
