Yokomo GT-4 Thread >
Yokomo GT-4 Thread
Yokomo GT-4 Thread
Old 12-09-2005, 12:14 PM
  #1306
anyone have a belt tensioner for sale?
prossi is offline
Old 12-16-2005, 10:16 AM
  #1307
prossi dude, please check your PM
flyingfox is offline
Old 01-04-2006, 09:04 AM
  #1308
flyingfox, wheres my stuff?
prossi is offline
Old 01-04-2006, 09:15 AM
  #1309
Quinton's Avatar
Any GT-4 hop-up parts for sale?
Quinton is offline
Old 01-04-2006, 11:22 AM
  #1310
have you received the item yet? my internet connection has just been re-connected.. will send the tracking number in 3hours
Old 01-04-2006, 03:10 PM
  #1311
flyingfox, thanks for the update. i sent you a PM.
prossi is offline
Old 01-04-2006, 04:07 PM
  #1312
Quinton's Avatar
Anyone know if you can use a belt tensioner and the pulley upgrade? And is the pulley upgrade worth it?
Quinton is offline
Old 01-04-2006, 04:39 PM
  #1313
quinton check your PM
prossi and quinton, i'm selling off my whole set of parts and upgrades for $220 shipped. let me know if you are interested.. maybe you guys might wanna split the parts among yourselves.. lower cost if 2 guys buy the whole lot.
Old 01-09-2006, 06:38 PM
  #1314
i have a GT4 for sale. Its complete ready to go. PM me for details. Great condition. im selling because its my extra GT4
prossi is offline
Old 01-10-2006, 02:16 AM
  #1315
so you have received the items already?
Old 01-10-2006, 05:57 PM
  #1316
yes i did, thanks, i didnt realize the clutch bell was for a centax.
prossi is offline
Old 01-11-2006, 02:00 PM
  #1317
i did tell you that it's for the centax.. by the way if you want the clutch shoe , spring and the flywheel i have those too
Old 01-11-2006, 03:02 PM
  #1318
yeah, i saw it in one of your pm's after it arrived...my bad, do you have everything to complete the centax? if not what else would i need?
prossi is offline
Old 01-11-2006, 10:27 PM
  #1319
ok i have the spring, clutch shoe, flywheel, thrust bearing.. you need the motor mount, spring retainer, pressure plate, shims and collet.. that's it.. by the way i have most of the centax pinions
Old 01-12-2006, 02:07 PM
  #1320
i currently have these up for grabs.. all are NIP unless stated
GT-4 hop-ups/parts new in package for sale. $220 shipped
ZE-002S 70-75 Alum Chassis (same as the one that comes with the GT-4 Pro kit)
ZE-412F Front anti-roll bar X 2
ZE-671MT2 Hollow Middle Layshaft X 2
ZE-609MS Clutch Spring, Soft (ZE-MTC) X 2
ZE-609MH Clutch Spring, Hard (ZE-MTC) X 2
ZE-610M Clutch Bell (ZE-MTC)
ZE-604M Flywheel (ZE-MTC)
ZE-633 Brake Cam X 3
ZE-673A2 Aluminum Middle Layshaft Mount
ZE-641 First Gear Hub 2-Spd X 2
ZE-630 Brake Disk
ZE-632H High Performance Brake Lining
ZE-631 Steel Brake Pad
ZE-631S Brake Pad Support
ZE-010FSA Front Axle, 2 pcs X 2
ZE-618 18T 1st Gr Pinion 2-Spd
ZE-621 21T 2nd Gr Pinion 2-Spd
ZE-617 17T 1st Gr Pinion 2-Spd
ZE-620 20T 2nd Gr Pinion 2-Spd X 2
ZE-615 15T 1st Gr Pinion 2-Spd
ZE-618-2 18T 2nd Gr Pinion 2-Spd
ZE-616 16T 1st Gr Pinion 2-Spd
ZE-619 19T 2nd Gr Pinion 2-Spd
ZE-615M 15T 1st Gr Pinion (ZE-MTC) X 2
ZE-616M 16T 1st Gr Pinion (ZE-MTC) X 2
ZE-619M 19T 2nd Gr Pinion (ZE-MTC)
ZE-620M 20T 2nd Gr Pinion (ZE-MTC) opened but unused
ZE-198 Rr Wide Drive Belt
ZE-001FS Urethane Bumper
ZE-644S 44T 2nd Gr Spur 2-Spd (For ZE-640S) X 3
ZE-645S 45T 2nd Gr Spur 2-Spd (For ZE-640S)
ZE-647 47T 1st Gr Spur 2-Spd
ZE-651W Muffler Wire
ZE-007H Fr & Rr Upper Arm Set, Hard X 2
ZE-415FB Front Steering Block (Type B) X 2
ZE-415F Fr Hub Carrier
ZE-001P Fr Plastic Bumper Set X 2
ZE-016R Rr Body Mount Stay
ZE-016 Body Mount Set
ZE-300RS Rr Bulkhead Support & End
ZE-300F Fr Bulkhead
ZE-008FH Fr Lower Susp Arm Set, Hard
ZE-415R Rr Hub Carrier
