Old 09-06-2002, 08:52 AM   #91
Racmark's Avatar
I guess I will go for the Yokomo grease. I'm also running a front one way, which grade would you recommend for the rear diff? Hard or medium?
Racmark is offline   Reply With Quote
Old 09-06-2002, 10:42 AM   #92
Well, if you stay that way then you could use either grease, but I'd probably stay medium. The thought being, the front one-way is basically a differential in the corners and a solid axle on-power, so when you gun it you want some front end pull which will happen with the one-way, but in the corners you don't want the rear to be stiffer than the front. That's all subjective, though, slight changes when using a front one-way can cause totally different driving styles, so hopefully people running that front one-way/rear diff will answer.
Kiaser is offline   Reply With Quote
Old 09-07-2002, 10:32 PM   #93
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Need to use the bandwidth again to post on Yokomo site.
Dan is offline   Reply With Quote
Old 09-07-2002, 10:36 PM   #94
Dan
Dan's Avatar
Old 09-07-2002, 10:39 PM   #95
Dan
Dan's Avatar
Old 09-13-2002, 08:31 AM   #96
Im curious as to when Yok is gonna release their new TC. Anyone hear any rumors or leaks?
calimassive is offline   Reply With Quote
Old 09-13-2002, 09:33 AM   #97
rod_b's Avatar
Send a message via AIM to rod_b
I don't remember where, but someone said possibly early next year. With the new Serpent and Mugens coming out, I'm sure Yok won't be far behind
rod_b is offline   Reply With Quote
Old 09-16-2002, 10:24 PM   #98
SpeedTech's Avatar
Hi Guys,
Coming soon, Kawahara Micro SS Centax Clutch for the GT-4! Pre-order now on our website.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 09-26-2002, 12:47 PM   #99
mo
mo's Avatar
I ran one of Smitty's 2-shoe 2-speeds this weekend. It's much better than the stock hammer type unit. No big rear end squat when shifting into 2nd anymore. I would recommend it two everyone. check it out at http://www.nwmcc.co.uk/smittysspeedworks/default.htm
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-26-2002, 04:09 PM   #100
IF anybody is interested, please drop me an E-mail at
[email protected]
And I can give you all the info needed.
Smitty
smittys800 is offline   Reply With Quote
Old 09-26-2002, 06:25 PM   #101
Dan
Dan's Avatar
smitty, send out mines yet?
Looking forward to using it at this coming month's race...
Old 09-26-2002, 07:28 PM   #102
Yep, yours is on the way!!
I did a little more work on the bell, be sure to show it off before you put on the car.
Let me know if you need any set up help with it!
Smitty
Old 09-26-2002, 11:11 PM   #103
acs
acs's Avatar
I heard that Chris T was using a Yokomo Prototype 2 shoe 2 speed at the World Cup. And that it would be released soon.
Anyone got more info?
BTW my Kawahara Centax is on the way. I can't wait.
acs is offline   Reply With Quote
Old 10-02-2002, 09:00 AM   #104
Racmark's Avatar
Default Car Tracking
Hi!
I'm having difficulty in getting my car to track straight. I think it's due to the unequal length of the steering rods. How do you know how much to adjust or the correct length on each side whenyou adjust the toe?
Old 10-02-2002, 11:29 PM   #105
Dan
Dan's Avatar
Check for tweak. Bent chassis or hinge pins might be a cause. Mis aligned wheel settings. Or unequal shock lengths can be a cause as well.
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
