Old 02-02-2004, 06:54 AM   #1021
afm
afm's Avatar
Default Re: Sad ending
Originally posted by Tabushi
Hi guys ...
This is just to tell you guys that i will not run the pre-worlds ... i had a problem (relatives issues) which made me spend a good amount of money to support them so i will not be money-ready to run the preworlds ... (i will have to save money to be ready for the local championships here and on my actual status i cant attend the two roads) ...
I will go to the preworlds to colaborate with Brazilian (and foreigner) Yokomo Team, take a lot of pictures and film-making ... but will not attend the event as a driver ...
Thanks a lot to all of you that send me letter with tips about setups and all ...
I will keep you informed as the event appear to start ...
cya again ! ...
Pato
Sorry to hear this, but such is life. My thoughts are with you. Hope everything turns out well for your relatives.
Keep us informed on the Pre-Worlds.
God Bless you.
AFM
afm is offline   Reply With Quote
Old 02-02-2004, 11:33 AM   #1022
Francis M.'s Avatar
sorry to hear you won't be able to race. it sounds like you were
getting ready for the preworlds for some time now. Theres always
a next time and good luck to you and your family.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-06-2004, 05:31 PM   #1023
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Where'd everyone go?!?
Old 02-06-2004, 07:47 PM   #1024
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Default spare Part
Hi every Yokomo GT4 owner. I looking for cheap GT4 spare part, any thing that can fit to GT4. If you have pls send me an email at [email protected]. TQ
tkhoo is offline   Reply With Quote
Old 02-06-2004, 10:08 PM   #1025
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
I have a bunch of parts new and used. Let me know what you need. Just been lazy to put them on eBay.
Dan is offline   Reply With Quote
Old 02-06-2004, 10:53 PM   #1026
tkhoo's Avatar
Default Part
I looking for front & rear lower arm left & right
bumper holder set
belt
all the above is the one the urgently needed but if you have other part pls send me the list and the price to [email protected]
TQ
Old 02-08-2004, 11:37 PM   #1027
nitrodude's Avatar
JWF-Franni. I need some setup help on the GT4 for Revelation, as you allready know. Im running 60wt oil all the way around with #2 Asso. pistons in the front and #1s in the rear. Springs, gray front, yellow rear. The shock position on the towers are the same as yours, and on the inside hole on the lower front arms. 3 degree camber in the rear, and 2 in the front. The toe in the rear is 2 degrees, in the front 1 degree toe out. The caster clips are all in the back of the arm.
Tires. I like to run 45f 42r, but sunday these were not working, so I runed 42f 40r, and the car was good.
My only problem is that I cant go into the turns with any kind of decent speed because it will traction roll, and honestly I have been stumped. I dont know what else try.
Thanks in advance.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 02-09-2004, 07:49 AM   #1028
Francis M.'s Avatar
nitrodude I already forgot what the piston # for ass. stands
for but I use the rayspeed pistons with 1x 1mm for the front
and 2x 2mm pistons for the rear. For your traction rolling
you really just need to cut the tires down and make sure your
tire diamm. is not over 60mm. The bite at rev on sundays is
just really good.
Old 02-09-2004, 08:03 AM   #1029
nitrodude's Avatar
The biger the number the more dampening it has, so the #1s are the lightest, and the #3s are the heaviest. i gues I will have to true my tires after all.
Steven Muller
Ronin Speed Parts
Old 02-09-2004, 08:09 AM   #1030
Francis M.'s Avatar
I think you'll just have to True your tires down because your
setup seemed fine you might need a little more dampening
but its hard to tell untill you have the right tires size on.
Old 02-09-2004, 10:03 AM   #1031
rod_b's Avatar
Send a message via AIM to rod_b
Francis - can you PM your setup for Rev? I'm rebuilding a GT-4 and want to try it out over there. Thanks.
rod_b is offline   Reply With Quote
Old 02-09-2004, 10:28 AM   #1032
Francis M.'s Avatar
I'll PM you the set up later when I get home. The car was
not bad last week but i was not great either.
Old 02-10-2004, 07:04 AM   #1033
Default gt4
To all tech master,
ihave a gt4 and i want to know what motor you all think i should run.
nitrohead..12 is offline   Reply With Quote
Old 02-10-2004, 07:14 AM   #1034
afm
afm's Avatar
Default Re: gt4
Originally posted by nitrohead..12
To all tech master,
It all depends on your budget, and if you want to race legal sanctioned races, club races, or just bash around parking lots.
There is a lot of possibilities, also LHS support is important.
What do you want to do??
AFM
Old 02-10-2004, 07:49 AM   #1035
Francis M.'s Avatar
ive heard that the NS12 or the Novamega SS is the way to go
now. I'm still using my JP s3 from last july so i'm going by what
the local guys are buying more of now.
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
