Old 01-05-2004, 12:11 PM   #841
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by jwf_frani
no ive been using this set for 3weekends now it is acually
3mm smaller front and back the tires are wearing down evenly
so i don't have to retrue to keep the correct overdrive ratio.
i run a ride hieght 4mm all around but if needed i can go
to 6-7 even with the tires being 3mm smaller from my set up.
just keep adjusting droop and guess what it works out better
for gearing.
Cool, how small can you get the tires down to before they are trash though?
Old 01-05-2004, 12:25 PM   #842
Francis M.'s Avatar
i will re measure my tires since it still has one good race day.
but i am hoping i can run the rears to 55mm. If you want to
run the standard pulley try starting at 60mm all around.
i know Chris T. was starting at 59mm.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 01-05-2004, 12:33 PM   #843
I havent planned on going to the overdrive pulley set, so I'll try using 58-60mm for starters.
Old 01-05-2004, 02:14 PM   #844
Francis M.'s Avatar
that should be in the ball park for rev. i'm actually gonna try
parking lot racing at lamirada this weekend i just want to see
how it will work just changing gearing.
Old 01-05-2004, 02:28 PM   #845
The La Mirada track was fairly low grip, so you'll propably have to go with a softer tire. There was also one bumpy section, so 4mm ride height wont fly well there...
Old 01-05-2004, 03:06 PM   #846
Francis M.'s Avatar
i'll probably try 5mm all around or 5.5 in the rear with softer
springs but will probably only adjust the ride height and try
it during morning practice before changing stuff.
Old 01-05-2004, 04:09 PM   #847
The track picked up a little more traction as the day went on, but still pretty slick. Dont use any sauce on the tires, it's like driving on ice...
Old 01-06-2004, 04:54 PM   #848
Francis M.'s Avatar
Tabushi have you had a chance to adjust your brakes or
something else in the car so that the car has better response
when applying the brakes.
Nitrodude looks like my plans fell through for lamirada because
a lot of the locals are racing at rev. Hope to see you at rev
this week end. Can you believe ive been running on the same
tires for 3weeks now
Old 01-06-2004, 08:35 PM   #849
nitrodude's Avatar
JWF_franni, I probably wont make it for this weekend, but will almost for sure on the 4th sunday. Yeah, Im used to running on a set of tires for a while, as you know I dont true them so they last. I wanted to ask you also if you use the front hubs that are designed to reduce traction rolling?
Do you know if the MTX3 or MTX2 centaxes will fit the GT4? After running at Rev 2 straight races I realised how much a centax is needed at a high traction track. I guess I learn the hardway.
Thanks,
Steven Muller
MPP Team Palmaris Racing
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 01-07-2004, 06:02 AM   #850
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Thanks,
Steven Muller
Steven,
Kawahara make a centax for the GT4, im not sure but i think its almost the same as for the MTX2 ...
cya!
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 01-07-2004, 08:19 AM   #851
Francis M.'s Avatar
re: mugen clutch on gt4
it should fit since the latest version of the clutch looks close
to the mugen but not sure if the threading on the mugen
clutch bell and gt4 pinions will mesh. Any way heres is the
picture of the latest GT-4 clutch. part#ze-mtcl
Old 01-07-2004, 08:26 AM   #852
Manticore's Avatar
R/C Tech Charter Subscriber
the kawahara ss clutch spring is a bit too hard and the fly weight is too light. you need to fill up the 3 holes with grub screws to make the fly weight heavier.
Manticore is offline   Reply With Quote
Old 01-07-2004, 08:29 AM   #853
Francis M.'s Avatar
oops heres the pic. hey manticore you respond to fast
before i could edit my first post.
Old 01-07-2004, 08:30 AM   #854
Francis M.'s Avatar
heres another pic with all the parts layed out.
Old 01-07-2004, 08:32 AM   #855
Francis M.'s Avatar
manti I just did not like the first version. but that could just
be me not adjusting it right.
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
