Old 01-04-2004, 11:57 PM   #826
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Randman
TTT, where'd everyone go?
i am here, with my mugen !
Manticore is offline   Reply With Quote
Old 01-05-2004, 08:02 AM   #827
Francis M.'s Avatar
RE: masami at worlds:
this is really the most active ive heard of masami in
the nitro class which is good for the development of the
new car. It just shows how much GP has gotten popular
in Japan including the first JMRCA nitro nationals where he
did real well.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 01-05-2004, 08:55 AM   #828
Francis M.'s Avatar
Ive been running the gt4 for 9months now and finally got the
car to work in a highbite track. Tested it 2 weeks in a row with
good results. I raced it last week and the car felt better than
my finishing result. but the over all balance of the car was awsome.
Old 01-05-2004, 09:02 AM   #829
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
JWF_Frani :
Can you post here your setup and some tips over your car ? ... wich hop ups are you running ? ...
cya !
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 01-05-2004, 09:21 AM   #830
Tabushi's Avatar
Default Question about brakes ...
Hi guys,
Even when is not a "problem", i was practicing last weekend with a couple of guys (MTX3 x2 and Nitro tc3 x1) and noticed that when i brake hard (i dont like to use brakes but on the track i was practicing i have one hard 180 curve that requires some brakes) my car slides during braking ... other cars just block the tires and break hard and i noticed that mine block the tires but it slides like "on ice" a little and after that it break.
So, any tip about this ?, its normal ? ... i tried loosing a little my breaks and it feels like the car stops better and it have less or no slide ...
Thanks in advance for any opinnion ...
cya !
Old 01-05-2004, 09:29 AM   #831
Francis M.'s Avatar
tabushi how is the bite in your track
Old 01-05-2004, 09:59 AM   #832
TexasRacer's Avatar
Send a message via AIM to TexasRacer
Anyone interested in my Yokomo that is on ebay?http://cgi.ebay.com/ws/eBayISAPI.dll...category=19168
TexasRacer is offline   Reply With Quote
Old 01-05-2004, 10:04 AM   #833
Tabushi's Avatar
I can say the bite its very high and the tire wear too ... (one full set of jacos 40's on 55 minutes run time) ...
Old 01-05-2004, 10:41 AM   #834
Francis M.'s Avatar
if you are using a oneway try going to a difflock for the rear gear
diff. this should give you better braking and set the brakes so
that the tires don't break loose.
here is my basic set up.
gearing 16-19 pinion with 49-45 spur w/overdrive gears.
engine nova jp S3 with yokomo milke pipe.
tire size 56mm front / 60 back.
oneway front / gear diff rear w ofna diff lock.
frontshock tower is aluminum outside shock position w/long
shockend to use out side arm mount.
spring grey. w/50 wt shock oil and 1x1mm rayspeed shock piston.
toe out 1 camber 1.5 track width 198.
tire shore 40 yokomo.
reartower inside mount with standard shock end
using gray springs w/55 wt shock oil and 2x1mm rayspeed shock
piston. 2.5toe in each side and 2.5 camber.
Old 01-05-2004, 11:24 AM   #835
Randy Caster's Avatar
Trader Rating: 46 (100%+)
What happened to the Kyosho?
Old 01-05-2004, 11:27 AM   #836
jwf, I didn't realize how small you were running your tires. Do you have any problem making ride height with them, and how long do they last?
Old 01-05-2004, 11:34 AM   #837
Tabushi's Avatar
Default Diff Setup
I would like to know wich configuration you guys see the most out there on your tracks ? ... :
1.- Full Differentials
2.- Front one way and rear solid axle
3.- Front one way and rear differential
4.- Front solid axle and rear differential
5.- Full solid front and rear
Here in Brazil with foams the most used at the tracks is front one way and rear diff ... and after that, full differentials front and rear.
cya !
Old 01-05-2004, 11:36 AM   #838
modellor's Avatar
Normally everyone (regardless of car) runs solid axles here now on small/medium tracks and on big tracks we run either full solid or solid rear/ one-way front.
modellor is offline   Reply With Quote
Old 01-05-2004, 11:42 AM   #839
For Revelation, I believe it's a front 1 way, and a very tight rear diff..
Old 01-05-2004, 12:03 PM   #840
Francis M.'s Avatar
no ive been using this set for 3weekends now it is acually
3mm smaller front and back the tires are wearing down evenly
so i don't have to retrue to keep the correct overdrive ratio.
i run a ride hieght 4mm all around but if needed i can go
to 6-7 even with the tires being 3mm smaller from my set up.
just keep adjusting droop and guess what it works out better
for gearing.
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
