Old 12-30-2003, 12:36 AM   #796
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Manticore
you will like it !
I know, I hear that I will be spoiled if I race over there...
Old 12-30-2003, 12:38 AM   #797
Manticore's Avatar
R/C Tech Charter Subscriber
you will see, dude !!
Manticore is offline   Reply With Quote
Old 12-30-2003, 12:47 AM   #798
hehe, I cant wait
Old 12-30-2003, 05:02 AM   #799
modellor's Avatar
i find out i dont use as much brake as the others do so i dont need a high torque servo for throttle. besides, it does look nice with a smaller throttle servo there !
That is very true. We both run the same type of style with little or no brake. I blew a KO servo a while back and for the throttle I was just using a standard Futaba 3003 out of one of my planes till I got it replaced. Didnt notice any big difference in performance and the standard servo is way lighter.
modellor is offline   Reply With Quote
Old 12-30-2003, 07:56 AM   #800
Manticore's Avatar
the reasons why throttle servo dies faster then steering servo is that
1/. excessive loading due to the dead loading on the braking servo arm.
2/. excessive vibration from the near end of engine.
Old 12-30-2003, 08:04 AM   #801
Francis M.'s Avatar
ive used the lowprofile futaba for the steering for the last couple
of outings now with out problems with performance (knock on wood)
NitroDude if you need any help at all with set up just let me
know and i'll try to help you. I'm also glad to hear that you
are gonna be coming down more often to rev it will be nice
to have more racers showing up but this weekend is KZ time
or blow my engine time
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 12-30-2003, 09:06 AM   #802
Default for sale or trade!
gt4w sirio.12 tons of spares tires parts hop ups newer body everything but a transmiter and rec!
bouncermike805 is offline   Reply With Quote
Old 12-30-2003, 10:45 AM   #803
Francis M.'s Avatar
don't sell it
Old 12-30-2003, 06:45 PM   #804
modellor's Avatar
Sorry Manticore. I should have mentioned that it was the steering servo that went. Didnt like playing with the boards. I swapped the KO from the throttle to the steering and put the standard in the throttle.
i had problems once with excess vibration but now I rubber mount the steering servo and attach using cable ties. I dont have any problems with dead loading. I have the brakes dialled out completely except for a little at the end of the curve to pass the stationary hold rule. When racing my throttle stick never goes back beyond neutral.
Old 12-30-2003, 08:42 PM   #805
Manticore's Avatar
ah, no problem.
you shouldnt have muchproblem with steering servo unless you crash it very hard !
Old 12-30-2003, 09:28 PM   #806
modellor's Avatar
ah, no problem.
Had to replace a pipe and manifold, a brand new bodyshell just on that day and bent the chassis.
A total of around 300 British Pounds (500US$). Wish I had been driving the Yokomo that day instead of the Serpent. It got worse abuse and still kept going.
Old 12-30-2003, 10:32 PM   #807
nitrodude's Avatar
Actually, JWF-Franni, my set up is in the ballpark. As I mentioned on sunday I need to work on tunning the engine. Where I usually run the tunning is totally different, I found out the other day that we run the low end on the lean side out here in Camarillo. And the car was over geared on second gear. If I can get those 2 things fixed, I will provably do some more setup work. Thanks anyways.
I want to get the hang of Rev, then I will try KZ, and once I got the hang of KZ it will be CP.
Since you guys brought it up, Im also getting used to running with out brakes. This past sunda I went out for the last qual. after having switched engines and the radio wasnt set right, so I freaked went I didnt have brakes, but it felt faster without them, just let the foams slow you down.
Thanks,
Steven Muller
MPP Team Palmaris Racing
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 12-31-2003, 03:58 AM   #808
Manticore's Avatar
This is from Futaba FAQ section:
What can I do to ensure long life of my digital servos?
The number one concern is tight linkages which have absolutely no binding, stiffness, or friction. Because digital servos are always working to hold in position at full strength, if the servo has a point it has to fight in the linkage it will literally burn itself out 'hunting' to try to hold its position. Slop at the neutral position is a very common problem where a standard servo wouldn't notice it but a digital servo will work very hard to try to hold the rod in position and will drain your batteries more quickly and eventually burn up the motor.
and some other FAQ here
Old 12-31-2003, 07:32 AM   #809
Francis M.'s Avatar
nitrodude good to hear you figured out what you have to do.
see you at the next race:
Old 12-31-2003, 11:24 PM   #810
Data's Avatar
Post
small picture of yokomo's prototype gp car, driven by masami - from jan 2004 rcworld.
Data is offline   Reply With Quote
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
