Old 12-22-2003, 11:11 PM   #721
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by jwf_frani
I don't know if anyone actually makes a single speed shaft
but you could just lock out 2nd but you might have to find
and pinion and spur combo that is tall enough for the main
straight but low enough to give you good accel. coming out
of corners.
I was just hoping to find a single speed shaft just to kill some rotating mass... I guess it doesnt matter too much, but I used to have an advantage over the 2 speed cars with my single speed.
Old 12-22-2003, 11:13 PM   #722
Originally posted by modellor
Very true.
I normally run with front and rear tires equal diameter and the 23T front side pulley to create a lot of overdrive to pull the car around the twisty short tracks. Many people dont like this method but it suites me fine due to not using brakes at all. Once you start driving this way and learn to control the steering with the throttle the lap times will really fall.
I may have to pick up that overdrive gear set, sounds pretty good for my driving style, I never use brakes... hell, all I use are 1 ways now anymore, so I couldnt really use em if I wanted to.
Old 12-23-2003, 08:10 AM   #723
Francis M.'s Avatar
Originally posted by nitrodude
Exactly what does the aluminum front side pulley do? I been using it and it handles good, but someone told me that its for high speed tracks, is there any truth to that?
Thanks,
Steven Muller
MPP Palmaris racing
Hi, steve the aluminum pulleys are overdrive pulleys. to make
it 1 to 1 you will need to run 4mm tire split. or you could run
it even like posted previously but i don't recomend running
that high of an overdrive at revalation or crystalpark for that
matter.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 12-23-2003, 02:18 PM   #724
Francis M.'s Avatar
here's a pic of my car that someone took at rev.
just put your arrow key towards the right bottom
corner of the pic and click to maximize the pic.
Old 12-23-2003, 04:12 PM   #725
Francis M.'s Avatar
another thing i'm working on with someone is a 3mm wider hex
with custom axle with 3mm more threading to off set the hex.
Old 12-23-2003, 04:34 PM   #726
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hi, how is it your experience with the centered tank upper deck from penguin rc ? -.. im using the normal upper deck from penguin, but i mounted the battery pack on the right side ...
hope you can write a little about the centered tank upper deck here ...
cya !!
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 12-23-2003, 09:30 PM   #727
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
harkonen the gtr rtr2 should be the best equiped rtr right
now. it comes with a 2speed aluminum pipe w/rear exhaust
so that should cover most of your needs as for speed.
the chassis is as close as you can get to the pro version.
Yes, the RTR 2 sure looks great however its something I cant really afford right now. Is that a shot of your GT4 for your icon? Nice paint job.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 12-23-2003, 11:07 PM   #728
What Car is that in the pic? jwf_frani
ckh1328 is offline   Reply With Quote
Old 12-23-2003, 11:08 PM   #729
second one
Old 12-23-2003, 11:09 PM   #730
last one.
just built it. still have to make some adjustment to it.
comments?
Old 12-23-2003, 11:09 PM   #731
forgot to post the pic.
Old 12-24-2003, 12:52 AM   #732
HarKonnenD's Avatar
Hey thats a nice upper deck. Is that the one from Penguin?
Old 12-24-2003, 12:53 AM   #733
What shock tower is that up front?
Old 12-24-2003, 04:08 AM   #734
modellor's Avatar
The car is a Yokomo but I believe Frani is using MTX-3 rear hubs and specially made upper rear wishbones which allow you to adjust camber and rollcenter.
Randman - The front shock tower looks like a stock GT4-R low tower used to run Lola shells.
modellor is offline   Reply With Quote
Old 12-24-2003, 08:03 AM   #735
Francis M.'s Avatar
RE: what car
it's a gt4 with cut down hubs with delrin insert. it is not a
mugen hub.
the front tower is a stock gt4r/penguin graphite. the reason i
went with this tower is i can use the outside holes in the arm
with out using the long shockends.
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
