Old 12-15-2003, 02:43 PM   #646
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by jwf_frani
most of the good racing should be with the sedan. You can
run a lola but the 200 outlaw gets thrown in with 235 class.
Aah, I see, and I'm guessing the 200 would get dominated by the 235's. Good thing I bought a sedan body
Old 12-15-2003, 04:08 PM   #647
drfritz's Avatar
I would not say that, we had a local boy race at a national race with the mugen mtx3 sedan and ran it in the 235 calss and put a hurt on those boys......
drfritz is offline   Reply With Quote
Old 12-15-2003, 08:41 PM   #648
nitrodude's Avatar
JWF-Frani, where you at the TFT race at Rev? ANd if so, did you run your Yok?
Thanks,
Steven Muller
MPP
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 12-16-2003, 12:43 AM   #649
Wow, I thought they were a lot faster...
Old 12-16-2003, 07:41 AM   #650
Francis M.'s Avatar
Thanks,
Steven Muller
MPP
i ran 1/8 scale all weekend. i'm still putting my yok back together
since it was taken apart at the nats.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 12-16-2003, 08:49 AM   #651
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Finally got my full weekend of practice over foams ... the track its this one :
Well ... my Yokomo its performing GREAT on foams, i used front 40's from Ellegi and rears 35's from Ellegi. Other combination that worked on similar way was full Jaco's 40's all over ...
Im runing front solid and rear diff and the rears were eaten very fast.
Next weekend will show up again on the track and will try front one way and rear diff and then front one way rear solid ... i remember when i run foams about 6 months ago i did the same test and stayed with front solid and rear diff option.
The only problem i found its that the rears ended just with 1mm of foam after a lot of running but only on the outside part, because the inside part its about 4mm ! ... the solution its just add camber ? ... the car did not change too much on performance from begining to end ... but the rear tires did !!! ... and the fronts suffered the same effect but just noticeable (very little) ...
Any comments ?
thanks in advance ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 12-16-2003, 09:11 AM   #652
Francis M.'s Avatar
fix your camber until your tire wear is even and you will notice
that your tire wear will slow down a bit. don't ask me to explain
but when the tires are coning on the outside the tire wear seems
to wear down 2 to 3 times faster.
Old 12-16-2003, 09:21 AM   #653
Diesel Racer's Avatar
Nice looking track!
Diesel Racer is offline   Reply With Quote
Old 12-16-2003, 10:00 AM   #654
Tabushi's Avatar
Mhhh ... right now im running 2 toe-in and 2.5 Camber on the rears ... so ... i do have to go up to what ?, 4 Camber on the rears ? ...
Thanks in advance ...
Old 12-16-2003, 10:07 AM   #655
InitialD's Avatar
Usually with foam tires, you need more rear camber than with rubber tires. -3 to -4 camber in the rear is normal for foam tires.
Old 12-16-2003, 11:21 AM   #656
Any comments ?
For that track, I'd reach for my 1 way front diff. As for tire wear, just change the camber and try to get them to wear somewhat evenly across the tire.
Old 12-16-2003, 11:23 AM   #657
Wow, I had no idea that you needed that much camber for these cars, wont that hurt performance at the beginning of the run when you are only driving on the inside of the tire?
Old 12-16-2003, 11:24 AM   #658
Francis M.'s Avatar
tabushi don't get too caught up in the #'s on your settings
just try to add camber until you minimize the tire coning.
also when the tires get smaller and you have to readjust the
ride height you will notice that your camber should be less than
what you started with on taller tires at the same camber settings
hope this helps. let me know if it works out.
Old 12-16-2003, 11:38 AM   #659
Francis M.'s Avatar
another thing tabushi you probably already know this but to
set your camber on the car set your ride height first using the
tires your running on and then make your camber adjustment.
Old 12-16-2003, 11:43 AM   #660
InitialD's Avatar
Yes, readjust ride height due to tire wear and you'll need to readjust the cambers. Not forgetting that you also need to readjust to give more droop.
If say ride height is 5 mm with 62 mm tires and droop of +4, tires wear down to 58 mm, then ride height should be at 3 mm [5 - (62-58)/2]. Droop should be increased from +4 to +2.
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
