Old 12-12-2003, 11:16 PM   #616
Can anyone tell me which belt break the most for GT4? the 192, 198, or the 351 belt. Thanks.
ckh1328 is offline   Reply With Quote
Old 12-13-2003, 06:34 AM   #617
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I dont know that the belts will break so easilly, but I know that with time, they do stretch out a bit. The longer center belt would propably have the most noticiable wear on it, might be good to have a backup, or just a belt tensioner.
Old 12-13-2003, 06:53 AM   #618
afm
afm's Avatar
In my 3 years with the GT4, definetely the belt that wears out and or breaks much faster than all is the front (ZE192), i'd say 2 to 1 of the others. That is because you normally use a heavier front diff.
Yes, the side belt (351) gets slack very soon, but that's why you need the side belt tensioner to tune accordingly as slack increases with time.
Never broke a rear or side belt, just changed them with normal wear.
AFM
afm is offline   Reply With Quote
Old 12-13-2003, 08:08 AM   #619
modellor's Avatar
I have 2 GT4's and both are still on original belts (even with a lot of testing on stony carparks). The first one which I still run was one of the first kits released.
The car is pretty solid and takes a real hammering. So far in 4 yrs I have only stripped a couple of gears and broke the front body post support. The gears were my own fault. I was adamant about getting the 15/19 pinions to mesh with the standard gears without altering the chassis holes. Just doesnt work.
I just sent you an email Randman.
modellor is offline   Reply With Quote
Old 12-13-2003, 10:07 AM   #620
Thanks.
Old 12-13-2003, 05:09 PM   #621
Got your e-mail, man, that's great news I replied back to you, look forward to hear more
Old 12-14-2003, 09:58 AM   #622
I am lookinga t getting the new Yokomo GT4W LImited edition car. I was just wondering if the car comes with all the aluminum hop-ups and if it comes with a centax clutch? Does it come just liek the picture that is ont he Yokomo USA site
FirstLoser is offline   Reply With Quote
Old 12-14-2003, 05:08 PM   #623
The W2 includes everything you listed there. Basically it's completely hopped up, the only thing I bought was titanium screws to shave a little weight, and add a little strength.
Old 12-14-2003, 07:09 PM   #624
Guys, I have a question about the rear suspension on W2L. The rear upper is 8.8mm and rear lower one is 9.2mm and one is 8.4mm from the GT4-W manual. I know that setting is for rubber tires, and the rear dog bones come with the W2L is somehow shorter. I mean if I use the stock setting for the rear arms, the dog bones are not long enough to stay into the outdrive. I can solve this problem by shortern the gap between the rear hub carrier and the arms, but I want to use 22 or 24mm rubber tires, and stay with 200mm width.
Can anyone tell me should I shortern the space between the hub and arms, or buy a longer dog bones, or other things?
Thanks.
Old 12-14-2003, 07:27 PM   #625
Thanks.
It sounds like by your description, that you need longer dogbones. I'm not sure if the length has changed, but the origional GT4 cars were based off of rubber tires, so it couldn't hurt to get a pair of the origional dogbones and see if they are a hair longer.
Old 12-14-2003, 07:28 PM   #626
I am having a problem on the rear arms with the dog bones. The dog bones are not long enough when I followed the stock setting to adjust the gap between the rear carrier and the arms, 8.8mm, 8.4mm, and 9.2mm.. Another setting is shortern the gap, but that setting is for 30mm tires. I want to use 22 or 24mm tires. Do you know which rear dog bones or rear axle I should order?
Yokomo
ZE-010FS Universal Part (Bone)
ZE-010AR GT-4 Rear Axle
ZE-010FSB Universal Part (Bone)
ZE-010BW GT-4 200mm Wide Dog Bones
I found these at speedtech.
Which one should fit?
Old 12-14-2003, 07:33 PM   #627
Yokomo
I'd think that ZE-010BW is what you'd be looking for...
Old 12-14-2003, 08:25 PM   #628
Thanks. Do you know do I need the same 200mm for the front too?
Old 12-14-2003, 08:27 PM   #629
nm, I think I don't need it for the front.
Old 12-14-2003, 08:27 PM   #630
On my W2, the front universals work fine, plenty long, and that is using the 200mm pivot balls.
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
