Yokomo GT-4 Thread
#586
R/C Tech Elite Member
Originally posted by jwf_frani
randman you can probably learn more from chris t about this
car since he's had 3-4 years experience with this car now and
ive seen a few of your posts were you know chris t. so i would
go to the best source for this car.
Chris and I will be in the Fukuyama booth at the Toys 4 Tots race in La Mirada, dont know if you're in the area at all, but if you make the race, drop by and say hi.
#587
I live in lahabra so it's pretty close by but i'm not sure if
i'm racing there or crystal park so i'll try to pass by if i can.
I'm actually gonna get started on electric again so i can get
more practice with different cars. I'll probably get the mr4bc
if you guys get a 4wd mod class going at socal.
#589
i guess it is a standard 3belt system but i can tell you it's
a lot smoother than the other belt driven cars ive owned in
the past anyone who's owned different belt cars and also
owned a gt4 will agree on this
Of all the 3 belts, I personally find that the center long belt plays the most part of getting the drivetrain to be free rolling.
I guess the GT4 comes with very good sets of belts and long lasting too which I believe they are.
#593
Originally posted by Randman
This thread always this dead?
Go to yokomousa forum. I believe they are move active over there.
#594
They are dead too.
I feel Gas is not as active as Electric
#596
But nobody around to answer my couple questions?
#598
Originally posted by InitialD
You mentioned earlier that you had a friend who gave you a lot of tips and that led you to getting the GT4. Why don't you ask those questions to him instead? Perhaps he knows the answers.
#600
Finally im running on foams downhere ... i bought front and rears 26mm and 30mm from ellegi and from Jaco (0 offset) ... all i did on the rears was to tight one and half round the pivot balls (maintaining the setup), add a shim between the hex hub and the wheel and i ended with a 199,8 rear width setup and no rub at all !!! ...
cya !
cya !
