Old 08-17-2003, 03:40 PM   #466
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
www.speedtechrc.com
They sell a lot of GT4 upgrades.
Dan is offline   Reply With Quote
Old 08-18-2003, 02:20 PM   #467
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Default Finally tested the mods ... 2 races so far ...
Finally tested the mods, 2 races so far ... the lateral balance its a lot better than before !! and the rear carbon post support its flawless ...
PIC 1 of 3 ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 08-18-2003, 02:20 PM   #468
Tabushi's Avatar
Default Pic 2 of 3
PIC 2 of 3 ...
Old 08-18-2003, 02:21 PM   #469
Tabushi's Avatar
Default Pic 3 of 3 ...
PIC 3 of 3 ...
Old 08-18-2003, 02:23 PM   #470
Tabushi's Avatar
Soon i will post here the last mod ... a front belt tensioner (for who, as me, always have problems on front solid cuting belts), so far its working GREAT, but we are working on a mod to let it be "adjustable" ...
cya !
Old 08-18-2003, 08:44 PM   #471
TexasRacer's Avatar
Send a message via AIM to TexasRacer
i have tons of problems i am trying the new front solid axle with a rear diff here is my set up and this is what happens it is really wierd when i am going into a corner the car will push in the corner and out. when i am going on the sweeper the car is doing fish tails it is wierd but what should i do
front
greay springs
80 weight
3 hole piston
all bump screws and down stop screws are tooken out
63mm shock length -2 camber
-1 toe in
rear
yellow springs
3 hole pistons
60 weight oil
-3degree camber
-3 toe in 63mm shock length
PLZ let me know asap whats wrong i am running foam tires and i need a set up bad for the roar even here in austin this weekend.
TexasRacer is offline   Reply With Quote
Old 08-18-2003, 09:23 PM   #472
modellor's Avatar
Ok TexasRacer -
It would appear you have a serious problem. Push is caused from the car being too hard at the front or too soft at the rear. The fish-tailing on the sweeper is most likely from the car being too soft or rolling to much.
Can you tell me if you are running any of the sway bars. Running the sway bars will help cure the fish-tailing problem. They will stiffen up the chassis and stop the car rolling about.
With the solid axle in the front you want to run the front end considerably softer than normal. I would suggest changing to grey springs on the front and probably 50 wgt oil in the front shocks.
You have mentioned whether you run foam or rubber tires. If you are running foam try running a shore softer on the front than normal to reduce the push in the slow corners. If running rubber then run the same tires all round.
With the foams, you might actually find that on some surfaces having a harder shore tire on the rear works better.
Try this first and we can start to get the car dialled in.
modellor is offline   Reply With Quote
Old 08-18-2003, 09:38 PM   #473
TexasRacer's Avatar
i run the front sway bar the softest setting and the rear sway bar the softest and i am running foam tirea and the car doesnt roll at all it is really wierd tried eveything let me know
Old 08-18-2003, 09:52 PM   #474
modellor's Avatar
Move the eyes on the rear sway bar as far back as you can get them. The roll may not be apparent but it is definately there under load in the corner.
What shore foams are you running? And what type?
Old 08-18-2003, 10:14 PM   #475
TexasRacer's Avatar
im not even sure im not a nitro races just got thrown a hole bunch of tires i am a electric guy i already have the sway bar all the way back just tell me a good set of shore for a black tar about 140degrees really smooth
Old 08-18-2003, 10:20 PM   #476
nitrodude's Avatar
Try 45 front and 42 rear, that should work good on most tracks.
Thanks,
Steven Muller
MPP
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-24-2003, 05:47 PM   #477
TexasRacer's Avatar
Well guys the car still didnt come around to work for some reason. But o well i think i am gonna get rid of it and change to a mugen mtx-3 so anyone looking for a yokomo gt4 pro with all the mods and tons of extra parts with a extra chassis.
Old 08-24-2003, 06:06 PM   #478
nitrodude's Avatar
You are going to get rid of the car because you cant get it to handle right? This is the reason RC cars today have the very sofisticated suspensions, so that they can be set-up for any track and any condition.
IMO, you should either get a front one-way or a front diferential, that will solve a lot of problems. The solid in the fron works, but it requires a different driving style that a lot of people are not used to.
Thanks,
Steven Muller
MPP
Steven Muller
Ronin Speed Parts
Old 08-24-2003, 07:21 PM   #479
modellor's Avatar
TexasRacer - I was just noticed you live in Austin. Are you racing on the track were the 1:8th on-road World Championships were held in '89/'91? Cant remember exactly which year but I think it was one of those.
That is one big track and would probably suit a really hard set up with a solid rear axle and front one-way.
Possibly brown springs on the front, light green on the rear. 80wgt oil in the front and 50 in the rear with anti-sway bars both at hardest setting and both big spacers in fron of the wishbone for caster angle.
For tyres I would say 45 shore front and 42 shore rear.
Start with 2deg camber on the front and 2.5deg camber on the rear with 0deg toe-in on front and 1.5deg toe-in on the rear.
I would never sell a car because I cant get it set up right. I would perservere until I do so. Changing the car wont cure the problem. All you will be doing is taking the problem with you. I know. I have done this many times. If I cant get a car to handle the way I want it too I now revert back to the factory settings and start again from scratch. I then just make single changes to see whether something works or whether it doesnt. But before I try another set up I always change the first one back to the factory setting. I always note down which changes helped and then once i have everything tried I start putting the different changes together in pairs and then in triples etc until I find the perfect balance.
Give this a try. You will be surprised.
Old 08-25-2003, 05:35 PM   #480
TexasRacer's Avatar
Well mostly getting rid of it cuz parts are hard to find and they have tons of mugen parts here all the time. Im not just getting rid of it because it wont set up right just time to try a new car out but if any of yall have a extra one way for sale or trade let me know i need the out drives also.
Thanks,
Cody Gary
Team Putnam Propulsion.
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
