Old 04-07-2003, 10:06 AM   #346
Well guys I am back.
Went to the opening race this weekend at Olde Towne Hobby in Manassas Va and had the worst push ever. I was wondering what you guys run for Toe in the Front and rear. I am running a gear diff in the rear and front one-way.
BallPy is offline   Reply With Quote
Old 04-07-2003, 10:43 AM   #347
rod_b's Avatar
Send a message via AIM to rod_b
Wow, if you're pushing with a one-way up front, you either had tremendous rear traction or zero front traction. I run 1 degree toe-out in front and 2 degrees toe-in at the rear. If you have lots of rear traction, then you shouldn't mess with the rear of the car. You need to add steering. Is it pushing on-power? off-power? First thing to try is tires. If you have lots of rear traction, I would add some rake (front end lower than the rear). There are other things to try also like droop, springs, etc but you have to describe the situation a little more because you don't want to adversely affect the rest of the car just to gain steering.
rod_b is offline   Reply With Quote
Old 04-07-2003, 08:51 PM   #348
Francis M.'s Avatar
ballpy what tires are you running. sometimes it could just
be as simple as that. if not what rod said
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-07-2003, 09:23 PM   #349
rod_b's Avatar
Francis - How do you like the car so far? How does it drive compared to the MTX3 and NTC3?
Old 04-07-2003, 11:06 PM   #350
Francis M.'s Avatar
i'm happy with the car i had some carb issue on an old
engine but i'm just 3/10 of my regular pace on the first
time out with the GT4. as for handling and gearing spread
out on the car i'm happy with it.
Old 04-10-2003, 10:11 PM   #351
M3
Ballpy
When you arrived at the track last Sunday your car had the front solid axle. When did you change it? What oil are you using in your shocks. What time are you going on Sunday?
M3 is offline   Reply With Quote
Old 04-18-2003, 08:24 PM   #352
M3
Ballpy
Are you going to Hobbytown next Sat.?
Old 04-18-2003, 10:50 PM   #353
about the centax clutch.. wuts the average shim setting for the front and the back shims.. I can't seem to get it right. it either locks the clutch to the clutch shoe when tightened or it's jus too loose. Sometimes the screw keeps changhing settings even if i use thread lock and let it dry fully.
rccraze is offline   Reply With Quote
Old 04-18-2003, 10:51 PM   #354
jus in case my engine is a sts rs3
Old 04-19-2003, 12:21 AM   #355
Hey rccraze
Are you having problems with the New Yokomo centax clutch??? I've been thinking about getting one, but if people are having problems, I'll wait until they get it right...
Bradley J. Gotori
[email protected]
bgotori is offline   Reply With Quote
Old 04-19-2003, 01:26 AM   #356
yes it is the yokomo centax
Old 04-20-2003, 01:44 PM   #357
2QCK2C's Avatar
Default A good setup
Hello Everyone,
I just got a yokomo gt4 and am wondering what would be
a good starting point for...
front camber, caster, toe
rear camber, toe... and so forth
The track we are racing on is ashfault, on road course. very smooth. I am using the following tires yokomo 138 gh (front)
yokomo 138 GF (rear) with firm inserts
Thanks in advance
2QCK2C is offline   Reply With Quote
Old 04-20-2003, 05:13 PM   #358
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
who has the s version?
cHckbOY5 is offline   Reply With Quote
Old 04-20-2003, 11:33 PM   #359
me ME i got a type S. Very lucky to get it too. All i can say now is
" The Few, The proud, The Marines (GT4 TYPE-S)"
Old 04-20-2003, 11:36 PM   #360
O BTW i got my centax figured out.. finally... I had to do some custom work in order for the clutch to fit properly and still spin freely. Now im enjoying my car. Beats my old hpi by many times
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
