Old 03-24-2003, 07:00 PM   #286
modellor's Avatar
Hmmm,
Solid axle front and rear.
Where did you get that from???????
Let us all know what you think about it. I remember when I mentioned the idea that everyone laughed and said it couldnt work. Now everyone is using it
modellor is offline   Reply With Quote
Old 03-24-2003, 07:54 PM   #287
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Heheheheh you are right modellor, the front and solid setup its great.
Even with that in mind, for a short/twisty/low-traction track as the one i usually run i prefer rear diff (very hard) and front solid.
PAT
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 03-24-2003, 08:02 PM   #288
Tabushi's Avatar
And this how it looks my 2nd room at the hotel where im living here in Sao Paulo for the last 12 months (a 2 bedroom hotel room, one big with desk, sofa and all and the other small with TV, desk and a bathroom ... so the small its my workshop heheheheh the people at the hotel is not very happy but for a 2 year hotel renting contract they accepted me heheheh).
Old 03-25-2003, 03:42 AM   #289
vulso's Avatar
Tabushi: HAHA! I love it! Lot better than the bench at the end of my bed
Modellor: It works great ! Everyone at the track thinks I am crazy! I don't think they have heard of that set-up before. By the way what is a good set-up for the front? It pushes like a pig! I run on a short parking lot track. The back end sticks like glue, there is no oversteer in the car at all. I have yellow springs on the rear and gray's up front, but I am having trouble dialing in front grip.
vulso is offline   Reply With Quote
Old 03-25-2003, 05:44 AM   #290
modellor's Avatar
Vulso,
If you are using the front anti-roll bar you may have to loosen it off. Take off small amounts at a time until the front stops pushing. If it is completely loose and still the front end pushes can you swap cars with me
Only joking, my car pushes at the front too now that the weather is changing and the grip level has increased significantly.
I like to run 1 deg of toe-in on the front wheels which would account for some of my push but I found that now that the grip is picking up I am having to run the front of the car a lot softer to compensate for the rear grip.
I run on foams so my options for changing set up where restricted more. I softened the front (something I hate doing). Try running a silver spring and work with the anti-roll bar to get a nice feel. If you still get push then try using a shore softer on the front tire.
My current set up for the twin solids is:
Front
Silver Springs
2deg camber
one thick spacer in front for caster
1deg toe-in
40shore foam tires
60wgt shock oil
front anti-roll bar at 45deg angle
Rear
Yellow Springs
2deg camber
1deg toe-in
37shore foam tires
40wgt shock oil
rear anti-roll bar at hard setting (as far back with the eye as possible)
floating rear body mount
I also run stock rear side pulley and alloy front side pulley
68% steering dialled in.
This is only reference as it suites my driving style but it may not be ideal for a different style. But it will give a good starting point.
Old 03-25-2003, 04:05 PM   #291
Default rbx12t 5 Port
hi guys! Just got my first rbx12t 5port engine. Can you please give me pointers on proper break in procedures? Thanks.
pcjr is offline   Reply With Quote
Old 03-25-2003, 04:52 PM   #292
rod_b's Avatar
Send a message via AIM to rod_b
pcjr - read the thread "Novarossi .12 5 Port Break In" That thread has a lot of suggestions as well as a copy of the RB break in procedures.
rod_b is offline   Reply With Quote
Old 03-25-2003, 07:00 PM   #293
sent u a PM modellor
rccraze is offline   Reply With Quote
Old 03-26-2003, 02:20 PM   #294
SUp all?
This is my First YOkomo Nitro. Ive been driving yokomo for a long time now. I got the GT4-W With X12 engine used. I was wondering what hop ups should i get . I know i should get threaded shocks. But what else One-way? Solid rear axle? tell me what stuff i should get for this car. There are gear Diff all around :-( . And can anyone give me a decent Crystal Park setup?
Yokomo_King is offline   Reply With Quote
Old 03-26-2003, 09:42 PM   #295
NitroMugenLV's Avatar
I am so searching for the Yokomo GT4 S-Type 1/10th sedan RC car. I have been wanting this car ever since I saw it hit the Yokomo website, but everytime I have the money saved up to buy the car, ITS GONE!!!!!!!
Yokomo needs to release more of these cars to the hobby shops. Cause I know for a fact that there are alot of Yokomo Fanatics out there dying to get this car.
Steve (SpeedTech) - Do you have any idea when this car will be available again?
NitroMugenLV is offline   Reply With Quote
Old 03-27-2003, 06:15 PM   #296
Ron C.'s Avatar
Exclamation
Originally posted by rod_b
In the rear, I believe they do. Just like their older 32mm foams.
Rod B,
Did you know that Francis just got a
new GT-4.?
He is now officially one of us!
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 03-27-2003, 06:39 PM   #297
rod_b's Avatar
Ron - I heard that. Ian said he was gonna be one of the "Team" drivers. If that's so, that is too awesome. I've decided to work on my Yok instead of replacing it with the MTX-3. Now that Francis is "one of us" that just helps me out. Now there are 2 of you guys I can ask when I have no idea what's going on with my car.
Old 03-27-2003, 11:00 PM   #298
Francis M.'s Avatar
hey rod I just started putting the car together then stupid me
glued the brake pads on the wrong side of the plate. got it
fixed, everything went together pretty good. i'm going to
try the rear solid on the car and mess around the the rear
diff later if needed.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 03-27-2003, 11:09 PM   #299
GT4-W what parts should i get for it?
Old 03-28-2003, 03:46 AM   #300
vulso's Avatar
YOKOMO_KING I am trying the solid front and solid rear setup for the parking lot track I run on. I supposed to be good for short to medium tracks. There are alot of ways to go with set-up for the Yokomo:
front rear
one-way solid axle comes on GT4R
solid axle rear diff comes on GT4 RTR
solid axle solid axle
front diff rear diff
It all depends on what you want try and buy and what suits your driving style and track the best.
As far as hop-ups, I am looking at getting the Centax clutch and new Shoe-Type two speed. The aluminum parts are good and look nice, but they are heavy. I hear they and strength though, so it is kind of give and take. I also got the Penguin RC carbon disc, I heard it's better to use them with regular pads than the hard pads because of wear. I like the 32mm rears as well, on the 190mm rear width set-up. SpeedTech RC has practically every hop-up you can get for GT4, I would cruise the website and see what you like. Hope this helps.
vulso
Yokomo MR-4 TC Thread Speedo Electric On-Road 2868 05-05-2015 03:38 PM
Yokomo MR4 BX thread..... cantona Australian Racing 110 10-04-2006 02:39 PM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
Yokomo new belt thread ttso Electric On-Road 1 02-23-2005 12:12 PM
Yokomo MR-4TC Thread v.2 The Black Kat Electric On-Road 1 04-18-2004 10:12 PM
