Old 12-20-2004, 06:03 AM   #1
Default relube bearings
I am rebuilding bearings on nitro cars. Just wonder whether there is any difference in how to relube bearings for electric cars and nitro cars.
I was told to get rid of the thick (lithium) grease in the bearings in EP cars, and lube them with just bearing oil to minimize friction
For nitro cars, do you just relube the bearings with bearing oil?
raceblast is offline   Reply With Quote
Old 12-20-2004, 08:00 AM   #2
i use remington gun oil. works great!!!
Joe Chaplow is offline   Reply With Quote
Old 12-20-2004, 09:30 AM   #3
i know you can get it at wallmart. probable kmart and places like that carry too. maybe target.
Old 12-20-2004, 05:15 PM   #4
Rapid Roy's Avatar
A lot of nitro guys do the same as the electric with the bearings. Just remember, the thinner the lube, the more often you have to re lube them. I use 5-50 wt synthetic motor oil. A little thicker, but pretty much set and forget.
Rapid Roy is offline   Reply With Quote
Old 12-20-2004, 08:43 PM   #5
Is it a good idea to lube the bearings of nitro cars with lithinum grease?
Old 12-20-2004, 09:08 PM   #6
mistercrash's Avatar
R/C Tech Charter Subscriber
This is just my opinion. Any car, nitro or electric, that is raced or bashed outside should have their bearings relubed with grease instead of light oil. The surplus grease in a bearing will form a ridge on the inside of the shields, and dirt or pebbles that do get in the bearing will be trapped in that ridge of grease. This ridge of grease will hold those debris, keeping them from getting in the balls too often and wrecking havock inside the bearing. With light oil, the dirt and pebbles float free inside the bearing and just keep on scratching the balls. Don't let pebbles scratch your balls guys, use grease if you're going to play outside.
No brain, no headaches.
mistercrash is offline   Reply With Quote
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 09:38 AM
Dry bearings mcc-bri Electric On-Road 29 01-31-2005 12:49 AM
Bearings karter Electric Off-Road 2 05-08-2004 03:43 PM
New bearings fasteddie d Nitro On-Road 2 04-11-2004 10:03 PM
Next Best Bearings To Ceramic Bearings????? J Smith Electric On-Road 47 08-21-2003 03:26 PM
