Old 12-17-2004, 10:27 AM   #1
Scott S's Avatar
Trader Rating: 30 (100%+)
Default R40 Clutch Problem
Hey guys, I need a quick answer..
I'm having trouble on a brand new R40 with the clutch not engaging. The problem is definetly the clutch, not the drivetrain as the wheels will turn when you turn the spur gear by hand. I start the motor and the clutch does not engage. Everything seems to be assembled correctly, but I'm just not sure how to adjust the centax clutch. The instructions are no help, so I'm turning to you guys.. help!
Thanks guys.
Xray T2 007 | Xray T2 | CRC 3.2R | CRC Gen X
Willis Hobbies | 360 RC Speedway & Hobbies | LIR
Scott S is offline   Reply With Quote
Old 12-17-2004, 10:31 AM   #2
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
scott needs help shouldnt you be working, come to think of it right now arent you working at a hobby shop doing a customer repair
Javen13 is offline   Reply With Quote
Old 12-17-2004, 10:54 AM   #3
Scott S's Avatar
You guessed it Justina. I cant figure out a customers car, hopefully someone with experience with a centax clutch can help me out..
Old 12-17-2004, 11:28 AM   #4
yeah gas cars are too damn annoying and break down a lot
Old 12-17-2004, 12:43 PM   #5
rowveg36's Avatar
Trader Rating: 21 (100%+)
try to put a shim behind the flywheel colet.
rowveg36 is offline   Reply With Quote
Old 12-17-2004, 01:04 PM   #6
TexasRacer's Avatar
Send a message via AIM to TexasRacer
I wouldnt put a shim behind the collet that will mess up the front bearing on the motor from rubbing on it. It might be because you need to loosen the nut that tightens down the clutch sping loosen it almost about a half turn and go from there.
TexasRacer is offline   Reply With Quote
Old 12-17-2004, 02:36 PM   #7
Scott S's Avatar
I think I solved the problem guys, like TexasRacer said, it was the nut that holds on the centax clutch. I loosened it up quite a bit and the clutch finally started engaging. Thanks for the help!
-Scott
Old 12-19-2004, 09:16 AM   #8
I had the same problem, you need to besd sure you have the correct ammount of shims and your going to have to loosen the black spring tentioner thing....i dont know what its called, but im sure you know of that super strong spring in the clutch assembely. just loosen it a little at a time untill it is smooth enough for you. trust me..this is your problem. if you got anymore Q's just pm me.
Chad_R40 is offline   Reply With Quote
Clutch Problem vazzo Nitro On-Road 8 06-20-2008 07:24 AM
Clutch bell problem ERL2004 Nitro On-Road 4 10-31-2007 06:18 AM
rs4 3 ss clutch problem . never lift Nitro On-Road 3 01-20-2006 02:27 PM
Clutch Problem B3boy Electric Off-Road 2 04-06-2003 12:20 PM
Is this a clutch problem? albertlam Nitro On-Road 31 03-17-2003 09:18 AM
