Old 08-16-2005, 08:18 AM   #211
I dont know how you are able to break drive shafts. Do they make a hardened steel version? I dont know if cvds would solve your problem, but in theory the pin in the cvd may be the weak point and instead of the whole shaft itself. tHIS IS WORTH A TRY.
Later
nitroracer20 is offline   Reply With Quote
Old 08-16-2005, 09:04 AM   #212
Rapid Roy's Avatar
They do make hardened drive cups and shafts. Check out the parts lists for the RS4-3 SS .18 kit. I beleive those parts are included in that kit.
Rapid Roy is offline   Reply With Quote
Old 08-17-2005, 05:53 AM   #213
rbridd's Avatar
OK. It sounds like I may have a deeper problem then if breaking driveshafts is unusual.
Cups yes - Shafts no. They are listed with the same part number 86036.
I have no problem with the cups. The shafts break at the weak point, where the diameter is slightly less, just in front of the ball.
I have not been able to find any reference through google, of an uprated driveshaft part.
So the question now is... Why are my shafts breaking?
rbridd is offline   Reply With Quote
Old 08-17-2005, 06:51 AM   #214
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Maybe your clutch engagement is too harsh. Does it seem like it jets off quickly?
Artificial-I is offline   Reply With Quote
Old 08-17-2005, 08:48 AM   #215
Rapid Roy's Avatar
Pulled this out of an old thread
the rear universal propeller shaft is the BEST upgrade you can ever invest. When you install a high end engine, the stock shafts break easily. I broke at least 9 pcs and had to install the part from hot bodies. (the front univ front shaft, by the way, is included on the package)
Old 08-17-2005, 08:53 AM   #216
Rapid Roy's Avatar
Here's the link to the thread. About half way down the first page is a picture posted. I couldn't get the picture to display with the post. Hot bodies makes the CVD type drive shafts. They come in a set of front and rear
http://www.rctech.net/forum/showthre...ighlight=rs4-3
Old 08-17-2005, 09:10 AM   #217
rbridd's Avatar
Thank you.
I think this is what I've been looking for.
Part number is HB61142 for rear shaft only. 7.99 UKP
Old 09-13-2005, 02:09 AM   #218
KillWency's Avatar
hey guys. what is the difference between an rs4 evo with an ss and a plain rs4 kit pullstart?
are the parts interchangeble? i picked an rs4 evo for my nephew coz its durable and the parts are cheap and more resistant to breakage than ntc3 at the track. no offense to ntc3 people but that kit is just way too brittle for newbies and basher kids. what upgrades are recommended to make it even more bulletproof?
KillWency is offline   Reply With Quote
Old 09-14-2005, 02:16 AM   #219
billysss's Avatar
Default difference
if you will be upgrading, the best is to look for the parts now onboard the 18SS. the 18ss kit is fitted with more impact resistant parts, however, you cannot race it since it is equipped with an 18 engine, race spec is 12 only. To compete in teh HPI class the HPI XS12 engine is the best engine, and but it has to be started with a starter box. Lately i have fitted a centax clutch of HPI R40 and it worked too well i can race the A class now with my rs4. Change the spur with 41-45 combination and teh green pinions for even faster speeds. However, remember, speed = greater breakage. I will try to post the pic of my revised rs4 fitted with gears from teh 18ss, it rips and it doesn't break now. The first change though after fitting a good engine is to fit the heavy duty center axles from hot bodies, theyre bullet proof, if you dont, you will hate the rs4.
got to race...and temporarily forget the mess we're in...
billysss is offline   Reply With Quote
Old 12-10-2005, 01:00 AM   #220
billysss's Avatar
Default hello rs4 owners
hello to all rs4 owners, the forum quite stucked up, seems the guys have shifted
Old 12-11-2005, 11:53 PM   #221
Jye
does anyone who has the graphite upper deck for the rs4 3 know if i have to use a stick pack with it?
Jye is offline   Reply With Quote
Old 12-12-2005, 07:10 PM   #222
billysss's Avatar
Thumbs down upper deck
the graphite upper deck is always available, the problem with it is that you will be denied quick access to thorough cleaning, and quick disassembly, i personally would not recommend it as the difference in weight is negligible.
Old 12-12-2005, 07:19 PM   #223
silver_spo0n's Avatar
Default jye
i has a slot for the old batt, a stick pack can also be used
silver_spo0n is offline   Reply With Quote
Old 02-05-2006, 07:40 AM   #224
Default 1st gear pinion unscrewing
I'm new to the RS4 Evo. Purchased a used one. When I start it up the 1st gear pinion unscrews off of the clutch bell. Is the 1st gear spur one way bearing my problem?? It seems OK (ie only turns in one direction). Any ideas please
HPI GUY is offline   Reply With Quote
Old 02-05-2006, 12:08 PM   #225
Moderator
Clegg's Avatar
a dab of thread lock will fix that.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
