Old 12-07-2004, 10:26 PM   #1
civiclized esi's Avatar
Default Engine needs HELP
HI ,
there is this problem with my engine, every time after a couple of runs my engine will behave strangely. It will intermittently power on and off even in WOT seems that it is running out of breath. can anyone Help thanks
civiclized esi is offline   Reply With Quote
Old 12-07-2004, 10:41 PM   #2
subman's Avatar
what type of engine?
What temp is it running at?
Clean air filter?
what car/clutch?
some questions that might help.
subman is offline   Reply With Quote
Old 12-07-2004, 11:02 PM   #3
InitialD's Avatar
Default Re: Engine needs HELP
Have you checked if the plug you're using is still good? I had that happen once or twice and after a change of plug, the problem went away.
Old 12-08-2004, 12:12 AM   #4
Clean air filter?
what car/clutch?
Engine : GS15R
Temp : 140
Glow plug : New OS NO.8
Car : V ONE S II
Air filter : clean after every run
Old 12-08-2004, 01:37 AM   #5
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by civiclized esi
Engine : GS15R
Temp : 140
Car : V ONE S II
Dude, you are overheating your motor! Try to keep the temperature in the 110C range.
jeffreylin is offline   Reply With Quote
Old 12-08-2004, 02:13 AM   #6
adamkerrnz's Avatar
what % nitro are you using? what % oil. could be the oil in your fuel. cut the drivers side window out of your body, give it more air to breathe...
adamkerrnz is offline   Reply With Quote
Old 12-08-2004, 02:41 AM   #7
Team-RTR's Avatar
jeffery, he isnt overheating his motor. the GS15R has been known to run in excess of 300F just to make enough power
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 12-08-2004, 02:48 AM   #8
jeffreylin's Avatar
No kidding?!?! Wow I've killed a couple of Nova based engines running at that temperature.
Old 12-08-2004, 05:41 PM   #9
I am using blue thunder 10%. Don know whether it is due to the fuel I am using right now.
Old 12-08-2004, 10:59 PM   #10
subman's Avatar
Check and make sure you have no leaks in the fuel/pressure line.
Old 01-02-2005, 05:45 AM   #11
bulletdays's Avatar
Default civiclized esi
I think you better check the glow plug type that u're using, and retune your engine, it just needs a little tuning it sounds like lean. also check for air leak especially in the primer. better to remove it...
bulletdays is offline   Reply With Quote
Old 01-02-2005, 06:26 PM   #12
AndyT 's Avatar
I have a friend who`s also running a GS15 and its regularly above the 300 deg f mark.........even when running super-rich and no body on the car its on the 300 deg mark......must just be inherent to this engine.
Having said that though, his engine is super- reliable......I`ve never seen it flame-out and starts very consistently.
AndyT  is offline   Reply With Quote
Old 01-03-2005, 12:02 PM   #13
Send a message via AIM to finbone
I have 2 novarossi engines that run right at 300. haven't hurt them yet, but i don't recomend it either.
finbone is offline   Reply With Quote
Old 01-04-2005, 04:12 AM   #14
asw7576's Avatar
Could you just replace the heatsink with bigger ones ?
With stock engine, I don't think so much about overheating.... infact I might do some crazy experiments to get the most power. Maybe over 30% nitro, drilling the carburator inlet to make it bigger diameter, widening the sleeve's ports.
Definetely you need bigger heatsink to make it last.
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 04:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
