Old 06-24-2002, 12:07 AM   #31
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Mixed Compounds Most people around here run slightly harder compounds on the front compared to the rear (usually 45/42 or 42/40 f/r) so, yeah, it's fairly normal or typical. If you think about it, too, it makes sense.
Compound Rating If you are in a place where you get Jaco foams, they aren't in shore ratings, they are in color - Ppl is about 40, Double Ppl is 42, that is what a lot of people run. I think Jaco is coming out with a new "plaid" but I don't know exactly what that is yet.
warped tire - Don't know anything you can do about that. I have tried bending it back a bit, but never gotten it right. I usually either run it if it doesn't wobble too much and if it doesn't feel bad, otherwise I relegate it to practice.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-25-2002, 05:45 PM   #32
I recently got an Ofna Colt 10 on road. I talked to my sales rep @ Ofna Steve. He told me because I wont be running on a permament track to try the 45-40 or 40-35 but I might need to go past the 5 shore difference, 40-30 maybe. Or a 35-30.
Any thoughts? The local track is blown off, thats it. Fine textured asphalt.
Foger Rox is offline   Reply With Quote
Old 06-26-2002, 02:57 PM   #33
Default Settings for foam
Hi Guys,
Great thread, I'm learning loads!!
One question:
To stop foam tyres chunking what do you need to do with your cars settings?
Softer suspension?
Shocks upright or more of an angle
Camber?
Toe-in?
Caster?
I'm running a Mugan MTX-2
Thanks in advance
Click, Dublin
click, dublin is offline   Reply With Quote
Old 06-26-2002, 03:16 PM   #34
To help with chunking, I understand that when you true the tires - - round off the corners.
Old 06-26-2002, 03:50 PM   #35
Joel Lagace's Avatar
Avoid chunking by:
-Trimming your wheel openings larger then you would for a concours body. Really though open them up and test hit your body from behind make sure your body cannot get snagged under a wheel.
-dont hit walls. (ya i know none of us here hit walls)
-round the edges of your tires after truing
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 06-26-2002, 04:06 PM   #36
mugenman's Avatar
Send a message via ICQ to mugenman
ill hit poles aswell as walls
im not fussy
LOL
mugenman is offline   Reply With Quote
Old 06-26-2002, 05:57 PM   #37
Francis M.'s Avatar
I personally use fast tires or Ufra
just because that is what i get a good
deal on as for different brands they all
seem to work it's just that i already
know which shore to use for my car
on fast tires and ufra. as for rubber
vs foam i only go to rubber tires for
concrete tracks or a real dusty track.
Francis M. is offline   Reply With Quote
Old 06-26-2002, 08:55 PM   #38
im not fussy
LOL
This guy Wilson, he hits me - - - - into the wall.
Old 06-26-2002, 09:00 PM   #39
Sure sure. This is second to "The curb jumped out right in front of me. I swear."
Sydewynder is offline   Reply With Quote
Old 06-27-2002, 04:28 AM   #40
mugenman's Avatar
isnt wilson that soccer ball
Old 06-27-2002, 07:32 AM   #41
LOL, he he - - but much fatter ! ! And it was the curb that jumped out in front of my 1:1 car ! ! Twice, I swear ! !
Actually he hit me twice in a large parking lot where we had set up cones.
Both times he had trouble starting his car, got it going - - then did a one man drag race across the "Track".
Then he did basically the same thing to someone else 2 weeks later. So that was 2 bent chassis.
Cant get the drag race mentality out of some folks, ERF ! !
How about shore #'s for a blown off but otherwise unprepped Parking lot track (very new & fine textured)? Lower the shore? And/or go to more than 5 shore difference? Like a 45/37? Or can I get 37/30?
Thanks,
Roj.
Old 06-27-2002, 09:42 PM   #42
mugenman's Avatar
ive found on a blown but unprepared 37 rear 42 front
or at the softest 35 rear 40 front.
i wouldent go eny softer on nitro thay seem to get to sqermy
and wear way to fast.
Old 06-27-2002, 10:31 PM   #43
Boomer's Avatar
yeah, these cars are heavy enough and powerful enough to make softer tires flex more so the cars would get, as you very well put it, squirmy.
shouldn't really need softer tires - the cars are heavy enough to generate the heat needed to make the tires stick - they always do for me at 40ish.
Old 07-04-2002, 02:54 PM   #44
Thanks Mugen Man, I'm going with 2 hole pistons all around, 80 wt/f & 60wt/r. I think I'll try the 42/37 combo. I still havent worn out the foams the Colt 10 came with, they are Ok. Who knows what oil came in the kit. But the car is close to hooking up now. I can power out of a turn at all but full throttle.
Roj.
Old 07-07-2002, 04:19 PM   #45
Trader Rating: 49 (100%+)
Default What is Shore Rating?
So what is shore ratings on tires anyways? How is it different from durometer readings? And can you compare the two? If so, how?
I understand the the lower the durometer rating, the softer the tire. Same from the shore ratings. I'm just trying to figure out why people went away from using a durometer?
And can you measure a shore rating on a tire? If so, what do you use?
thanks.
rodneybarrett is offline   Reply With Quote
F/S: New buggy tire & foam tire lot!! Dasupacat1 R/C Items: For Sale/Trade 7 06-28-2008 11:32 PM
Foam tire q's VenturaDC Electric On-Road 0 03-19-2008 04:29 PM
Foam Tire Lot RandyB R/C Items: For Sale/Trade 3 12-08-2006 07:39 PM
Rubber Tire vs. Foam Tire on Carpet dizzy1 Electric On-Road 34 06-07-2005 02:51 PM
1/12 pan car FOAM TIRE LOT Arun R/C Items: For Sale/Trade 3 10-03-2004 10:29 AM
