Old 08-30-2012, 03:19 PM   #271
Roelof's Avatar
Send a message via ICQ to Roelof
Yes, Picco is also still running an MRX4X and runned the finals with the EC-A. The original MRX4 from many years ago was not much different than the MRX4X.
Look at the NT1, an old design with small improvements while all other brands are 1 or 2 generations further....
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-30-2012, 05:19 PM   #272
wingracer's Avatar
Trader Rating: 24 (100%+)
Yep. Just an "optimized" MTX-3
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-30-2012, 10:56 PM   #273
MRX4XXXX's Avatar
So true!!
-X-
MRX4XXXX is offline   Reply With Quote
Old 08-30-2012, 10:59 PM   #274
MRX4XXXX's Avatar
Also Lamberto based his prototypes on MRX4 based contstructions before his new career with Capricorn.
-X-
Old 08-31-2012, 12:53 AM   #275
romain_f's Avatar
As I started this post, I would like to give my conclusion on the new rule, I race 1/8 and in france tire treatment is illegal and the weight was down to 2400g.
For the first point it failed.
Even if it's illegal, some drivers used tire treatment during nationals and no controls were done!! And machines and products have been best seller by distributors. So I guess next year we will use Efra rules concerning this point.
Concerning weight reduction, I think it's a good idea. On my strong and heavy Motonica, I only had to invest in LiFe batteries and titanium pivot balls, less than 100$! And I didn"t have to worry about loosing lead or even breaking something!
I used less belts and maybe the most fun thing is that making the five minutes qualifying was a lot easier!
Less weight can also mean less wear!! And even if you hit hard it's less kinetic energy against the wall...
So 1/10 driver think about it! I agree maybe 1550 is to much at once, but if one car manufacturer can do it why not!!
HB R8/Novarossi
romain_f is offline   Reply With Quote
Old 08-31-2012, 04:30 AM   #276
JamesHealey's Avatar
-X-
The NT1 is much closer to the MRX-4 than the MRX-3, but for sure it's definitely an evolution of the Mugen design.
But they've all gotta have 4 shocks, 4 wheels, a fuel tank and a chassis etc.. there has to be an optimal layout, look at full size F1 cars, how many of them have different layouts?
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 08-31-2012, 07:28 AM   #277
Regarding the evolution of the 1/8 rules.
First of all we all want fast and driveable cars, and to hold the 1/8th class as the kingdoms class.
I think it therefore seems logical that a reduction in weight limit follow the evolution of the cars and materiales used ... 2400 gr seems to be be a fair limit nowadays.
Regarding fuel to 16% and 8 mm restictor i'm not sure ... the goal is to reduce noice, why not let the 25% and 9 mm restrictor go on as today, and set up a progressive reduction in noice over a couple of years, and force the manufactors to develop exhaust systems that reduce the noice - I'm sure the knowledge is there to reduce noice a good amount without any significant loss in engine performace, if none at all.
Best wishes; Jens
jensroland is offline   Reply With Quote
Old 08-31-2012, 11:02 AM   #278
Roelof's Avatar
Tire treatment is a huge discussion in the Netherlands. It is not allowed because when it was voted for most drivers were still against alowing it. Today more than 50% of the national drivers are doing it and there is nothing you can do about it. If you buy an expensive MiniRae sniffer then most people will swap to less detecting treatments like castor oils or other natural oils.
There is no way you can role it out.
Best wishes; Jens
Look into large races before the 7 minute qualify rule. People were driving 16% and 8 or even 7mm ristrictors to get the 5 minutes. Did it make less noise? No!
The 30xx exhaust was a starting point but sadly there were to many problems. The MACH track in Heemstede (homebase of Sander de Graaf) was forced to use additional silencers which semed to work a lot but also had influence on the tuning of the engine so now today they only drive N21-3T basic engines to keep de noise down without tuning problems.
Te goal is now set to the HiPex exhaust which seemed to be based on a 2015 pipe with an extra housing arround it as a 4th chamber.
Old 08-31-2012, 11:49 AM   #279
wingracer's Avatar
I could be wrong but I seem to remember that when the boat guys around here first started trying to reduce noise, they didn't change pipe rules. You could run the exact same pipe you always had, you just had to add an additional muffler that attached to the end. I wonder if something like that could be done for cars.
Team Shepherd USA
Old 08-31-2012, 12:37 PM   #280
Roelof's Avatar
Like this:
As mentioned the MACH track has runned something like this and suddenly they stopped using this.
Old 08-31-2012, 01:48 PM   #281
Send a message via MSN to PMSorber
and force the manufactors to develop exhaust systems that reduce the noice .....
Will never happen...
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 08-31-2012, 02:00 PM   #282
NikoRacing's Avatar
nono guys this are wrong ways to reduce noise. 30xx series imposed by EFRA was a flop and sure this silencers added to the pipes are not the way. Just ask yourself where can you mount this objects on 1/10 touring car ...???
I already said something before. I work in Hipex and test for them, and be sure we found a good way to make noise down. Our pipe is already EFRA approved as 2095 and it works like normal pipes in performances and fuel consumption.
The major problem is that people here are not sensible to the noise problems. I heard AMSCI men say "no, I dont see the problem of the noise like a real problem..yeah they close a track in Netherland but the rest is ok". But believe me the problem do exist in Italy also. Track are closing and many has problems with houses around and so. Many want to forget about the problem but we cant do it forever. We just have to believe that it's possible reduce the noise without kill the engines.
In the last month we worked on a 1/10 prototype also and it works. No problem with temperature and consumpion is normal. We made 104km/h top speed and the pipe has lot of punch (the same is for the 1/8 offroad one, so we have good feeling because both are giving the same impressions).
Next year I believe it will be the good one.
I cant say more now. We hope to close the tests in October and then I will tell you more!
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 08-31-2012, 02:03 PM   #283
NikoRacing's Avatar
WRONG! HAHAHA
HIPEX is doing it!
the why is that we only make pipes. So we want to develop this product and we believe that all is possible.
Yeah if you ask to engine manufacturer..they only want more noise and more power and less cost to develop new products. Pipes are ok like this... why change??? -.-
Old 08-31-2012, 02:45 PM   #284
wingracer's Avatar
Keep at it Nicola, we do need to get the noise down.
I remember going to a race in New Jersey and after the last heat, I left to go get some food. Two miles away with a hill and lots of trees between me and the track, I could still hear the cars.
Team Shepherd USA
Old 09-01-2012, 01:12 AM   #285
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Totally agree with Niko, the Hipex 1/8th pipe is 10 or more db quieter then Sirio pipe and some 6-7db quieter then 2015 pipe.
tl2111 is offline   Reply With Quote
The New Werks B5 .21 Racing Engine Werks Offroad Nitro Engine Forum 9312 11-08-2017 11:45 AM
ROAR new body rules pdmustgt Nitro Off-Road 361 05-24-2011 03:25 PM
New Ener-G 4600 Ni-MH Cell Kropy Electric On-Road 507 09-15-2009 10:53 AM
New EFRA 7min Qualifying Rule Michael_T Nitro On-Road 36 03-01-2009 09:44 AM
