Old 10-20-2011, 08:56 PM   #1
Default HPI rs4 3 evo needs help!
i just recently got my hpi rs4 3 evo for some reason now when i start it up something engages the clutch nd the tires start spinning right away then dies out i crashed once or twice could i have done something to it? please help with some ideas i recently greased up the clutch shoes nd bell but no luck
mattrs4evo is offline   Reply With Quote
Old 10-20-2011, 08:59 PM   #2
cdewalt1985's Avatar
Trader Rating: 17 (100%+)
check your clutch spring
HPI Baja 5B/T Conversion 27cc cy Traxxas Slayer Pro 4x4 3.3
HPI Baja 5B 27cc ZN Traxxas Tmaxx 4x4 3.3
HPI Baja 5B 27cc ZN Pro Mod
KM Ksrc002 30cc
cdewalt1985 is offline   Reply With Quote
Old 10-20-2011, 09:03 PM   #3
i did it seemed fine idk what its suppose to look like it seemed in check but idk
Old 10-20-2011, 09:05 PM   #4
it just hooks to itself, wraps around the outside of the shoes, possibly lower your idle or check your oneway bearing
KM Ksrc002 30cc
Old 10-20-2011, 09:07 PM   #5
then all thats fine bc i the spring seems fine on the shoes so idk
Old 10-20-2011, 09:19 PM   #6
007kel's Avatar
Send a message via AIM to 007kel Send a message via Yahoo to 007kel
What kind of motor are you running? How long have you been running it (gallons etc.)? Check that LSN (low speed needle) and make sure it's adjusted to get the motor to idle.
KO PROPO HELIOS...yeah that's what I have left after leaving RC.
www.foundrycc.com
Instagram: 7kel
007kel is offline   Reply With Quote
Old 10-20-2011, 09:26 PM   #7
t3.0 but i shldnt have to adjust anything could my servo that controls the brake nd gas need to be adjusted?
Old 10-20-2011, 09:39 PM   #8
007kel's Avatar
Well generally, motors will need tuning. But since you mentioned you crashed a couple of times...your servo horn may have come loose, the broached portion is worn out, or something happened to cause the the throttle to open wide enough to get the motor's rpm high enough to engage the clutch.
www.foundrycc.com
Instagram: 7kel
Old 10-21-2011, 07:47 AM   #9
exactly but idk how to fix it nd right now i dnt got the money to take it anywhere to have it fixed
Old 10-21-2011, 09:10 AM   #10
Trader Rating: 2 (75%+)
Look in the engine forum here and then check out the Tuning bible.
fung_kyle is offline   Reply With Quote
Old 10-22-2011, 07:57 PM   #11
UPDATE: clutchbell nd shoe seemed fine greased them up when i tried to start it up again it takes off but i tried something new i unhooked the throttle cable from the servo nd kept it on the brake the wheels still turned also itll stop when i hit the break on the controller itll stop but once i left off the tires spine again, i tried the throttle trim it didnt do too much help tho it has to be somethin in the gears who the clutch is messed up i just didnt notice
Old 10-22-2011, 08:05 PM   #12
007kel's Avatar
Is the clutch bell moving free from the flywheel?
www.foundrycc.com
Instagram: 7kel
Old 10-23-2011, 10:18 AM   #13
i have no idea
Old 10-24-2011, 10:29 AM   #14
skuter-race-ta's Avatar
Trader Rating: 34 (100%+)
need help any idea or any link regarding the gearing chart for nitro rs4 3 ss kit?
or can you share any experience w/a .18 os cvr eng. and carbon vantage pipe..im asking what can you recommend for the gearing chart for this kind of set up?..coz i have this new kit installed all this things.
your help are very much appreciated ...tnx
traxxas revo 3.3........full mod hpi savage ss 4.6........full mod
t-maxx extended.......full mod kyosho mini inferno st elec...full mod
hpi baja 5b ss...........full mod ......26cc fuelie eng. ace r/c t6ac charger
hpi baja 5b 2.0..........full mod .....26cc zenoah eng./hpi baja v1..stock mod
hpi baja 5t trevor simpson eng. ...full mod bi-zeta racing crankshaft all steel crank
skuter-race-ta is offline   Reply With Quote
Old 10-24-2011, 10:56 AM   #15
if it accelerated a bit and then died, too lean low speed I think
you need to retune your carb, the needle might accidentally loose when you crashed
minilantern is offline   Reply With Quote
*NEED HELP ON GEARING FOR HPI RS4 3 EVO?* BIG DADDY8 Nitro On-Road 6 04-22-2007 03:00 PM
Engine upgrade help please?..? RS4 3 EVO DriveToLive Onroad Nitro Engine Zone 16 12-17-2005 02:47 PM
