Old 11-28-2004, 03:23 AM   #1
Smile novarossi .12
Hello,
I have a novarossi RS12T5S1 which i didnt use for quite a long time. I've replaced a piston/sleeve of these engine with a 3 port set bcoz i coudnt find a 5 port set in our LHS. After break-in I've noticed that the it takes time for the engine to idle. it's like my low end is lean but a lot of adjustment on the low end will not solve the problem, tried also adjusting the mid needle but nothing happen. Do you think it's the fuel that i am using? can i use a Byron fuel for my engine? Which glow plug im going to use it's already winter here in Dubai. Any help will be appreciated.
Thanks,
Jivikings
jivikings is offline   Reply With Quote
Old 11-28-2004, 12:59 PM   #2
Cool NOVA is fast!!!!!!
I don't know much about stting-up that kind of model but if it is in the fuel, I recommend you to use Traxxas top fuel or the Blue Thunder.
Breaker Z3 is offline   Reply With Quote
Old 11-28-2004, 01:01 PM   #3
Cool ebay
You can also find what you are looking for at www.ebay.com or www.hobbyworks.com.
Old 12-03-2004, 04:30 AM   #4
thank you guys, i think my engine needs more time to break-in. i will do it again this afternoon.
Old 12-03-2004, 08:18 AM   #5
Hi Jivikings- Please check if you are using the right plug and shim for 16% or 25% or 30% nitrofuel. They are different. Byron is a good fuel also make for Mugen Japon.
frankzettel is offline   Reply With Quote
Old 12-03-2004, 03:37 PM   #6
Trader Rating: 16 (100%+)
Default Re: novarossi .12
Originally posted by jivikings
Hello,
Thanks,
Jivikings
I am not the best engine guy to give opinion, but I too have the same engine...and I am not sure the CRANKSHAFT scoop area can be MATCH with the 3 port sleeve instead of the stock 5 ports sleeve.....I know there is a reason how the scoop where made with the 5 ports sleeve, but now you have replaced with a 3 port sleeve...I am not sure that might cause the idling problem.
Also, Byron fuel are good to use....1 of the top rank fuel for ppl that does not know how to make their own fuel or team driver...as long as you are not using something more then a month old, any fuel should be fine.
Yes, also check your plug, the shim thickness also depends on what % of fuel that you are using..
Then, the last thing, and the worst thing...AIR LEAK...it might be your carb, and the worst, the front bearing....those can be cause your engine not idling correctly.
Old 12-05-2004, 11:02 PM   #7
Hi,
With these engine i broke my fw05r, you know i want to throw it away. Temperamental I can say, when I make a full throtle it will stay there. Anybody want to buy these **** engine?
Jivikings
Old 12-08-2004, 11:13 PM   #8
Send a message via AIM to finbone
how much? I love the one I am running.
finbone is offline   Reply With Quote
Old 12-08-2004, 11:25 PM   #9
$250 bucks, or swap it with OS12TR R spec.
Old 12-09-2004, 12:32 AM   #10
TRAJ's Avatar
why are you selling it for???? The RS is a way better motor than the OS TR
the reason it got stuck at full throttle is maybe your throttle servo or radio set up!!
keep it man, it can be fixed.
TRAJ is offline   Reply With Quote
Old 12-09-2004, 01:03 AM   #11
I've got an air leak in the carb and i cant find O-rings on it, also these engine is only useful during winter in Dubai, weather here is devastating during summer, its useless. If someone wants to swap it with OS 12TR R-spec let me know.
Old 12-09-2004, 01:51 AM   #12
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I'm going to be out at full throttle Friday to Sun..I'm sure I have the o-rings you are looking for. Stop by and see me it my trailer.
Look for a white trailer with the dish on the back of it.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 12-09-2004, 02:44 AM   #13
Man I'm here in Dubai, how i can do that? wish i could fly. Saturday is the first day of upcoming Big Race. First will get a AED6000.00. second AED4000.00 and Third AED2000.00. That's the reason why I'm so frustrated with these engine it become erratic now that there's a big event. These December race is Sponsored by GM(general motors) they call it "CORVETTE CUP". There's no body shell to be use but Corvette from Kyosho.
Old 12-12-2004, 09:50 PM   #14
Finally my "NOVAFAST" is running fine again . I replaced all O-rings from ROSSI engine good thing one shop here selling ROSSI and they have a lot of spares for that engine. This afternoon is the start of corvette cup, I feel so tense about it. good luck to me.
Old 12-12-2004, 09:52 PM   #15
good luck in your upcoming races. glad you
got that nova running good again.
Joey
Difference between Novarossi 51603 tuned pipe and Novarossi RB x12 tuned pipe? racer rich Nitro On-Road 8 11-06-2010 07:52 PM
FS: 1/8 Kyosho Evolva + .21 Novarossi 359 + Novarossi .21 pipe + Tons of spares WogBoy Australia For Sale/Trade 6 05-15-2008 06:32 PM
Novarossi Plus 21-5KT (Turbo Plug) New in Box, AND Novarossi 21P5XS less than 1/2 gal nobike R/C Items: For Sale/Trade 29 04-01-2008 12:00 AM
Novarossi N528XR and Novarossi EFRA-9853 For Sale BAMF90 R/C Items: For Sale/Trade 9 10-11-2007 09:29 PM
NOVAROSSI 367 PLUS 2 pink_sleeve Electric Off-Road 3 05-24-2007 05:20 PM
