Old 10-03-2011, 01:59 PM   #1
Default identify this car
hi im new to the world of RC and have just got this car second hand from my LHS the engine was just broke in when i got it Well so ive been told, i have no books for the car or the engine the engine says its a novarossie sx 12 2.1 but i dont know what the car is so here is a few pics if anyone can help it wold be great, the fella in the shop said its a mugent and the other one said its a serpent 835 so feel free to take a quess again any help wld be great
identify this car-carpic1.jpg   identify this car-carpic2.jpg   identify this car-carpic3.jpg
rcnewb1979 is offline   Reply With Quote
Old 10-03-2011, 02:06 PM   #2
Serpent Impulse
I have seen Ralph Burch drive an RC car, It was an amazing thing to watch. So I joined his team and got the same car... XRAY and RC AMERICA
CFowler is offline   Reply With Quote
Old 10-03-2011, 03:25 PM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
I would say a Serpent 705
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 10-03-2011, 03:31 PM   #4
thanks very much for the replys its been doing my headin lol so its a serpent i can look at both and get the manual on them so onto the engine all i can see on the engine is nava sx12 2.1 and ive been on the website looking for the base settings and im a bit confused on the carb there is the HEN then below that there is a gold screw which i was told is the LEN but on the website it says that the LEN is on the rubber were the rod from the servo connects so what are the 3 screws for and which do i need to set for the base settings so i can run the engine as break just to be safe Thanks again for your replys
Old 10-03-2011, 04:17 PM   #5
wingracer's Avatar
Trader Rating: 24 (100%+)
Serpent Impulse with a few good hop-ups.
The big brass screw opposite the rubber bellows is the spray bar, sometimes called a midrange screw. It is generally best not to adjust it. Just set it flush and leave it alone.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-04-2011, 02:34 AM   #6
thanks for all your help lads now i can try and get it started and set right it did start then hit real hig rpm and cutout so now i know what all the screws are i can set it to base and start from there thanks again and if i need a little help i will be sure to ask atleast i know whati have now
Old 10-04-2011, 02:28 PM   #7
well got it started 2day ran for about half a tank good stream of smoke not boging or revving to high ran smooth though the speed then it cut out and took 30/40 min to start again then ran for the same amount of time and done the same what do yous think could be the problem
the way i have the screws is
HSN 1mm under flush
LSN 1mm over flush
mid range flush (as advised)
im useing 20% nitro
and a num 8 standard plug
Old 10-04-2011, 02:48 PM   #8
oeoeo327's Avatar
Trader Rating: 74 (100%+)
Check the Novarossi website for some advice on factory settings...
http://www.novarossi.it/eng/support/faq/
They are recommending 5 turns from closed on the high speed needle, and 2.5 turns from closed on the low speed needle as a good starting point. If the engine stops running after a few minutes, it's probably running a bit lean, causing the engine to overheat and shut down.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 10-04-2011, 03:01 PM   #9
thanks for the link its going to take some gettin used to this rc and engine tuning lol but im sure it will be worth it
Help Me Identify This Car! Klen420 Electric On-Road 26 09-21-2016 04:17 PM
Please Help Identify This Car TurbineTester Nitro Off-Road 12 06-26-2011 04:51 PM
Can anyone identify this car PLZZ!! DavisRCracing Nitro Off-Road 8 08-13-2008 05:36 AM
